Yes, you can do it by just dragging the other X variable. Test out the different graphs you can generate depending on where you place the other X variable. I used the Diabetes.jmp file to make the image below.
Created:
Jan 13, 2022 03:53 AM
| Last Modified: Jan 13, 2022 12:53 AM(994 views)
| Posted in reply to message from SDF1 01-12-2022
Thanks for the info. I was aware of this option but I was actually wondering if a secondary X axis, on top of each other and not next to each other would already be possible
Steven
Preview file
29 KB
videodata.push(data[i]);
catch(e){
/* Re compile html */
/* Adding Translation flag */
if (tr_obj.length > 0) {
try {
} catch (e) {
} else {
try {
tr_para.appendChild(tr_fTag);
else {
} else {
} catch (e) {
} else {
// syncList.remove(value);
if (index > -1) {
}else {
if (value == '450761' && "ForumTopicPage" == "TkbArticlePage") {
/* V1.1 Remove from UI */
var sub_L = "";
if (newSub.getAttribute("slang").toLowerCase() == code_l.toLowerCase()) {
if (value == '450761') {
else{
} else {
sub_L = newSub.innerHTML;
try{
catch(e){
if(subTkbElement){
try {
if(subElement) {
subElement.innerText = sub_L;
} catch (e) {
else {
try {
} catch (e) {
else {
try{
} else {
} else {
catch(e){
} else {
try {
else{
} catch (e) {
// Label translation
if (!labelEle) {
if (labelEle) {
if (listContains) {
trLabels = [];
trLabelsHtml = "";
/* try{
for(var j=0;j,';
trLabelsHtml = trLabelsHtml+'
