script to select all cols that contain a list of values?
I've got a large dt (70k cols, character) that I'm digging through. Most cols have a wide range of values, but a noticeable population of them have only two nuisance values. I want to identify all these cols and then dump them.
Any advice?
These nuisance cols will contain ONLY the terms "**skipped**" or "dne".
I've already dumped all cols that contain a single record value.
Re: script to select all cols that contain a list of values?
Here is a sample script
// Create a sample data table to be used for illustration
dt = New Table( "Example", add rows( 20 ) );
dt << delete columns( :Column 1 );
For( i = 1, i <= 100, i++,
	If( randomuniform( 0, 1 ) > .95,
		If( Random Uniform( 0, 1 ) > .5,
			dt << New Column( "col" || Char( i ),
				character,
				values( {"**skipped**"} )
				character,
				values( {"dne"} )
			character,
			set each value( Char( Random Uniform( 0, 100 ) ) )
// Below is the simple script that will build a list of columns to be deleted,
// and then delete them
colNames = dt << get column names(string,character);
colsToDelete = {};
For Each( {name}, colnames,
	If(
		N Rows(
			(dt << get rows where(
				as Column( name ) == "**skipped**" | As Column( name ) ==
				"dne"
		Insert Into( colsToDelete, name )
dt << delete columns( colsToDelete );
Depending on your data and the speed you need, you might want to change how you get the list of unique values, but below is one option
dt = New Table("Untitled 4",
	Add Rows(3),
	Compress File When Saved(1),
	New Column("Column 1", Character, "Nominal", Set Values({"dne", "**skipped**", "**skipped**"})),
	New Column("Column 2", Character, "Nominal", Set Values({"dne", "a", "b"})),
	New Column("Column 3", Character, "Nominal", Set Values({"**skipped**", "c", "d"})),
	New Column("Column 4", Character, "Nominal", Set Values({"dne", "dne", "**skipped**"}))
aa_colmask = ["dne" => 1, "**skipped**" => 1]; // we don't need the values, just keys
cols_to_remove = {};
For Each({colname}, dt << Get Column Names("String"),
	// depending on how much data you have, you might want to use different unique value techniques
	// Summarize, Associative Array and Summary are few options.
	// You can also first check if there are exactly 2 unique values, then check those
	aa_values = Associative Array(Column(dt, colname)); // I use AA here as it is the easiest option (not fastest!)
	aa_values << Remove(aa_colmask);
	If(N Items(aa_values) == 0,
		Insert Into(cols_to_remove, colname);
dt << Delete Columns(cols_to_remove);
