JSL: how to group all columns by common initial term?
I've got a dt (70k cols) that I'd like to group into common bundles, based on the initial delineated terms.
For example, 10K cols each that all start with "ChamberID", or "RecipeID", or "SlotNo".
How can I script this to churn through the dt to find all common cols, group them into a collapsible bundle?
Re: JSL: how to group all columns by common initial term?
Here is a little script that is an example of creating Column Groups in a data table.
dt =
// Open Data Table: semiconductor capability.jmp
// → Data Table( "semiconductor capability" )
Open( "$SAMPLE_DATA/semiconductor capability.jmp" );
colNames = dt << get column names( string, continuous );
group1 = {};
group2 = {};
For Each( {name}, colNames,
	/*If(
		Left( name, 9 ) == "ChamberID",
			Insert Into( group1, name ),
		Left( name, 8 ) == "RecipeID",
			Insert Into( group2, name )
	If(
		Left( name, 3 ) == "NPN",
		Left( name, 3 ) == "PNP",
dt << group columns( "NPN", group1);
dt << group columns( "PNP", group2);
There are many ways of doing this. I have used something similar as I demonstrate in below script (using associative array)
dt = Open("$SAMPLE_DATA/Probe.jmp");
aa_groups = ["DELL" => {}, "DELW" => {}, "RCON" => {}];
col_names = dt << Get Column Names("String");
For Each({col_name}, col_names,
	For Each({{key, value}}, aa_groups,
		If(Starts With(col_name, key ||"_"), // "_" is used as additional separator
			Insert Into(aa_groups[key], col_name);
			Break();
For Each({{groupname, groupcols}}, aa_groups,
	dt << Group Columns(groupname, groupcols);
If you need to go more dynamic you can also do that
aa_groups = Associative Array();
	nameparts = Words(col_name, "_"); // depending ion your columns, this might need to change
	If(N Items(nameparts) > 1,
		If(!Contains(aa_groups, nameparts[1]),
			aa_groups[nameparts[1]] = {}; // add new key
		Insert Into(aa_groups[nameparts[1]], col_name);
Idea is the same in both. Create associative array where they keys are column group names and the values are list of columns which belong to that group.
