PhiIippe
retrieve number of rows for data table and a subset
Hi, I need to know the amount of rows that are present in the parent data table as well as the amount of rows in a filtered subset of this parent table. But when I try to retrieve both in 1 script, it only gives me the amount of rows in the parent... Can you please help?
//parent data table
dt = Open("C:\JMP\yield_analysis_script\used_data\edit1.jmp","visible");
//save value
f=Col Number(:height);
//print f
title1 = "parent";
text1 = Text Box ("column f: "||Char(f));
New Window(title1,text1);
//subset of parent
df = dt << Data Filter(
Mode( Include( 1 ) ),
Add Filter( columns(:male_female),Where( :male_female == "M" )));
dftest = df << subset( selected rows(1), selected columns(0));
//save value
p = Col Number(:height);
//print p
title2 = "subset";
text2 = Text Box ("column p: "||Char(p));
New Window(title2,text2);
This is the result I get:
f and p are both equal to 6, while I expect p to be 3 (since I filtered out half of the rows..)
Does anyone see the issue here?
Thanks,
Philippe
Re: retrieve number of rows for data table and a subset
You are not pointing to your primary data table when you are doing your subset.  You are specifying
"df" is the pointer to the data filter not the data table.  You should be specifying
dftest = dt << subset( selected rows(1), selected columns(0));
Also, a better way to find the number of rows in a data table is to use the N Rows() function, not the Col Number().
numRowsMain = N Rows( dt );
// and/or
numRowsSub = N Rows( dftest );
// and/or
