emeritus
renew jmp14
 Time to renew my license.  Seems like every year I have this problem. (BTW this is a university license)
My license has expired.  I click "open license" I (think) I open the SID file.  the system returns a message that says my license has been accepted, but when I check the renewal date, it still shows the old expired date.
Help
Re: renew jmp14
There is a new SID file.  If you change the date in the SID file you looked at, the security code will no longer be valid, and it will fail to run.
Re: renew jmp14
Try starting JMP in "Run as Administrator" mode, and then updating the license. Also, make sure you are using your new SID file......
emeritus
Re: renew jmp14
I do remember the first problem was to set admin. user.
I right click on the JMP icon and click on "run as administrator"
That's fine.
Now, as you pointed out, the next trick is to use the right SID file, and I
am having trouble.
I have located both and SID and a PER file, but neither solve the problem.
Looking at the text in the file I see the old June 2020 license date.
As I think back, did I have to edit the SID file, or is there a new one I
am not seeing?
Thanks for your help
Re: renew jmp14
emeritus
Re: renew jmp14
It took me a while to figure out the admin privileges issue. You evoke it
by right clicking the JMP icon and selecting "run as administrator." I was
trying to do it in the windows settings.
Getting the right SID file was a bit trickier. If you run the old one, the
system returns a "license accepted" message but does not change the date.
I discovered a tab on my university's JMP download site that had one of
those 30 character file names with no explanation. When I did download it
I found it was the new SID file. So I copied it into notepad as a text
file and ran it. That worked.
All this confusion was caused because the Word document my university's IT
department posted failed to include the two critical steps mentioned
above. I flamed them and hope they actually fix it. Otherwise, I will go
through the same ordeal again next year. This was not a JMP problem.
Anyway thanks for the help.
