This widget could not be displayed.
Created:
Aug 20, 2020 08:06 PM
| Last Modified:
Aug 20, 2020 5:06 PM
(1745 views)
| Posted in reply to message from txnelson 08-20-2020
I do remember the first problem was to set admin. user.
I right click on the JMP icon and click on "run as administrator"
That's fine.
Now, as you pointed out, the next trick is to use the right SID file, and I
am having trouble.
I have located both and SID and a PER file, but neither solve the problem.
Looking at the text in the file I see the old June 2020 license date.
As I think back, did I have to edit the SID file, or is there a new one I
am not seeing?
Thanks for your help
