robhanssen
reference to a baseline value
We perform tests that measure performance of a device over time. The output is a value relative to the starting value. Right now to get to such relative performance, I setup a jmp sheet in such a way that I know what the reference is: Example:
Row     Device           Time               Performance
1             T1              0                     97
2             T2              0                     93
3             T3              0                     95
4             T1             100                    83
5             T2             100                    82
6             T3             100                    83
For the relative performance, I setup a formula script
perf_0 = match (Device, "T1", Performance[1], "T2", Performance[2], "T3", Performance[3]);
Performance / perf_0
This works well with a limited number of data points, but is prone to typing errors for large data sets. Is there a better way to have this automated and less prone to errors? Note that the Performance value at time 0, is not necessarily the maximum or minimum value.
ms
Super User (Alumni) ms
Re: reference to a baseline value
If the table is sorted after ascending time, this formula should work
:Performance / :Performance[Col Min(Row(), :Device)]
Here is a formula that will work.  I have also attached a data table with it applied.
currentDevice = :Device;
:Performance / :Performance[(dt << get rows where( :Device == currentDevice & :Time == 0 ))[1]];
Kevin_Anderson
Hi, robhanssen!
As you've intuited, there are probably better ways to do what you intend.
I would recommend a script with an Associative Array.  Please reference the Scripting Guide, and the JMP mockup of your dataset and an example of a script enclosed.
Good luck!
ms
ih
Super User (Alumni) ih
Some ideas:
  1. Make a new column indicating that the row is a baseline value, then search for it just as @ms suggested.
  2. Use a separate data table and a linked column to find the baseline.  I have not found a reliably way to script this yet but if/once that is possible it you could cross out #3.
  3. Use a separate data table and look the value up in that table (similar to vlookup).  A sample is attached, maybe someone knows of an easier formula though.
  4. Use a table variable. In the same sample script the device value pairs are on individual lines and parsed with regex.
praco
Hi all, I have the same question. However, I need a more reliable solution, I mean, not relying on row number, as my sheet can be mixed up.
So, is there a way to get the value from :performance of the row having the lowest value in :Time for each device, or even better: the value corresponding at Time=0 for each Device...
Maybe I'm not that clear...
Thank you
Nico
praco
Very nice! Thank's
Just to understand, what is the function of [1] in the formula?
Nico
