emdwright
"open" in JSL
I read the other discussion post with this name and I am having a slightly different issue.  I am using my work computer so security could be the actual issue.  I have tried to open a file from my OneDrive, Desktop and from a thumbdrive.  Does this script look correct?JSL_OpenError.PNGJSL_OpenError.PNG
emdwright
Re: "open" in JSL
Whoops I figured it out!  The file path needs an extra ".JMP" on the end.  I thought the extension was ".tab" but I turned on "Show all file extensions" and saw there was more.  Thanks!
emdwright
Re: "open" in JSL
Oh I guess disregard that I opened it manually too :p
emdwright
Re: "open" in JSL
