hogi
Level XIII
"apply" value labels
When I remove a formula from a column, the calculated values stay.
When I remove a Value Labels Property from a column, the values switch back to the original values.
Is there an alternative remove (~ "apply") function for value Labels, which converts the data type of the column to character and keeps the Value Labels?
dt << New Column( "sex2",
	Formula(Recode(:sex,{Map Value( _rcOrig, {"F", "female", "M", "male"} )}));
dt:sex 2 << Delete Formula;
dt:sex << Value Labels( {"F" = "female", "M" = "male"} ) << Use Value Labels( 1 );
dt:sex << delete property( Value Labels );
Re: "apply" value labels
After you have Value Labels set
and you go to recode columns you will have an option for recoding them
this seems to replace the values with labels
Removed to reduce confusion.
hogi
Level XIII
wonderful, thanks!
