Username01
"This feature is not interactive"
I've developed a dashboard with 6 Graph Builder visuals. Within JMP software, all graphs talk to each other. I cannot say the same with the exported Interactive HTML with Data when opened in both Edge and Chrome browsers. I am presented with a "This feature is not interactive" when attempting to click on the graphs. Are these not yet available to use for Interactive HTML? Please help.
View more...
Open("M:\Finance\Decision Support\Username Files\Username\JMP\Press Ganey\Press Ganey data.jmp");
JMP App(
	Set Name("Dashboard"),
	Set Description("Hierarchical selection filters a report"),
	Auto Launch(1),
	Snap To Grid(1),
	Show Grid(1),
	Show Properties(0),
	Show Sources(0),
	Group By Category(0),
	Dashboard Mode(1),
	Parameters,
	Tables(
		DataTable1 = GuiTable(
			Set Path(
				"/M:/Finance/Decision Support/Username Files/Username/JMP/Press Ganey/Press Ganey data.jmp"
			Set Label("Press Ganey data"),
			Location("Full Path"),
			Invisible(0),
			Set Script(
				Open(
					"$DOWNLOADS/Copy of PG Medical Practice Comments Jan-Mar 2023 for Username.xlsx",
					Worksheets("Sheet1"),
					Use for all sheets(1),
					Concatenate Worksheets(0),
					Create Concatenation Column(0),
					Worksheet Settings(
						1,
						Has Column Headers(1),
						Number of Rows in Headers(1),
						Headers Start on Row(1),
						Data Starts on Row(2),
						Data Starts on Column(1),
						Data Ends on Row(0),
						Data Ends on Column(0),
						Replicated Spanned Rows(1),
						Replicated Spanned Headers(0),
						Suppress Hidden Rows(1),
						Suppress Hidden Columns(1),
						Suppress Empty Columns(1),
						Treat as Hierarchy(0),
						Multiple Series Stack(0),
						Import Cell Colors(0),
						Limit Column Detect(0),
						Column Separator String("-")
	Thumbnail(
		New Image(
			Char To Blob(
				"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",
				"base64compressed"
			"png"
	Script(JSL Quote(// This script is executed when the application is run.
// Named objects have been created for the application modules
// (for example, "Module1") and the pre-defined object
// "thisApplication" refers to the application object itself.
// Variables and functions declared here are scoped to the
// Application namespace.
	Allocate(
		Module1 = Plan(
			PreAllocate,
			Script(JSL Quote( thisModuleInstance << Create Objects; Try(MainTabPage << Set Scriptable Object(thisApplication));
			Allocate(
				DataFilterContext1 = Data Filter Context Box();
				MainTabPage = Tab Page Box();
				Splitter1 = H Splitter Box();
				DataFilterSource1 = Data Filter Source Box();
				Splitter2 = V Splitter Box();
				TabPage2 = Tab Page Box();
				Scroll2 = Scroll Box();
				Report2 = Platform(
					DataTable1,
					Graph Builder(
						Size(547, 262),
						Show Control Panel(0),
						Variables(X(:Site Name), Overlay(:Reaction)),
						Elements(Bar(X, Legend(2), Bar Style("Stacked"), Label("Label by Value"))),
							Dispatch(
								"400",
								ScaleBox,
								{Legend Model(
									2,
									Properties(0, {Fill Color(32)}, Item ID("Mixed", 1)),
									Properties(1, {Fill Color(19)}, Item ID("Negative", 1)),
									Properties(2, {Fill Color(38)}, Item ID("Neutral", 1)),
									Properties(3, {Fill Color(36)}, Item ID("Positive", 1))
				DataFilterSource2 = Data Filter Source Box();
				Splitter8 = H Splitter Box();
				TabPage3 = Tab Page Box();
				Scroll3 = Scroll Box();
				Report3 = Platform(
					DataTable1,
					Graph Builder(
						Size(100, 234),
						Variables(Y(:IT SPECIAL)),
						Elements(Histogram(Y, Legend(2), Counts(1)))
				Splitter4 = H Splitter Box();
				TabPage4 = Tab Page Box();
				Scroll4 = Scroll Box();
				Report4 = Platform(
					DataTable1,
					Graph Builder(
						Size(100, 234),
						Variables(Y(:Provider ID), Overlay(:"*Rate provider 0-10"n)),
						Elements(Histogram(Y, Legend(2), Percents(1))),
							Dispatch(
								"400",
								ScaleBox,
								{Legend Model(
									2,
									Properties(
										0,
										{Line Color(-13948116), Fill Color(-13948116)},
										Item ID("5", 1)
									Properties(
										1,
										{Line Color(-11587507), Fill Color(-11587507)},
										Item ID("6", 1)
									Properties(
										2,
										{Line Color(-9226897), Fill Color(-9226897)},
										Item ID("7", 1)
									Properties(
										3,
										{Line Color(-6932080), Fill Color(-6932080)},
										Item ID("8", 1)
									Properties(
										4,
										{Line Color(-4571470), Fill Color(-4571470)},
										Item ID("9", 1)
									Properties(
										5,
										{Line Color(4), Fill Color(4)},
										Item ID("10-BEST PROVIDER", 1)
									Properties(
										-1,
										Item ID("", 1)
									Properties(
										-1,
										{Line Color(3), Fill Color(3)},
										Item ID("0-WORST PROVIDER", 1)
									Properties(
										-1,
										{Line Color(-15295028), Fill Color(-15295028)},
										Item ID("1", 1)
									Properties(
										-1,
										{Line Color(-14913825), Fill Color(-14913825)},
										Item ID("2", 1)
									Properties(
										-1,
										{Line Color(-14467343), Fill Color(-14467343)},
										Item ID("3", 1)
									Properties(
										-1,
										{Line Color(-14209626), Fill Color(-14209626)},
										Item ID("4", 1)
							Dispatch(
								"Graph Builder",
								FrameBox,
								{Fill Selection Mode("Selected Same Color")}
				TabPage5 = Tab Page Box();
				Scroll5 = Scroll Box();
				Report5 = Platform(
					DataTable1,
					Graph Builder(
						Size(100, 234),
						Variables(X(:"*Rate provider 0-10"n)),
						Elements(Bar(X, Legend(2), Label("Label by Value")))
				TabPage1 = Tab Page Box();
				Scroll1 = Scroll Box();
				Report1 = Platform(
					DataTable1,
					Text Explorer(
						Text Columns(:Comment),
						Set Regex(
							Library("Money"),
							Library("Common Emoticons"),
							Library("Words"),
							Library("HTML Link Grabber"),
							Library("Time"),
							Library("Numbers"),
							Library("Phrasing Punctuation")
						Show Word Cloud(1),
						Layout("Centered"),
						Language("English")
			Organize(
				Reparent(Scroll1(Report1));
				Reparent(TabPage1(Scroll1));
				Reparent(Splitter1(TabPage1));
				Reparent(Scroll5(Report5));
				Reparent(TabPage5(Scroll5));
				Reparent(Splitter4(TabPage5));
				Reparent(Scroll4(Report4));
				Reparent(TabPage4(Scroll4));
				Reparent(Splitter4(TabPage4));
				Reparent(Splitter8(Splitter4));
				Reparent(Scroll3(Report3));
				Reparent(TabPage3(Scroll3));
				Reparent(Splitter8(TabPage3));
				Reparent(DataFilterSource2(Splitter8));
				Reparent(Splitter2(DataFilterSource2));
				Reparent(Scroll2(Report2));
				Reparent(TabPage2(Scroll2));
				Reparent(Splitter2(TabPage2));
				Reparent(DataFilterSource1(Splitter2));
				Reparent(Splitter1(DataFilterSource1));
				Reparent(MainTabPage(Splitter1));
				Reparent(DataFilterContext1(MainTabPage));
				Relocate(DataFilterContext1(0, 0));
			Initialize(
				DataFilterContext1 << Background Color(2147483647),
				DataFilterContext1 << Border({Left(0), Top(0), Right(0), Bottom(0)}),
				DataFilterContext1 << Enabled(1), DataFilterContext1 << Horizontal Alignment("Default"),
				DataFilterContext1 << Margin({Left(0), Top(0), Right(0), Bottom(0)}),
				DataFilterContext1 << Padding({Left(0), Top(0), Right(0), Bottom(0)}),
				DataFilterContext1 << Text Color(2147483647), DataFilterContext1 << UI Only(0),
				DataFilterContext1 << Vertical Alignment("Default"),
				DataFilterContext1 << Visibility("Visible"), DataFilterContext1 << Set Min Size(717, 333),
				DataFilterContext1 << Set Max Size(30000, 30000),
				DataFilterContext1 << Set Stretch({"Neutral", "Neutral"}),
				MainTabPage << Background Color(2147483647),
				MainTabPage << Border({Left(0), Top(0), Right(0), Bottom(0)}), MainTabPage << Enabled(1),
				MainTabPage << Horizontal Alignment("Default"),
				MainTabPage << Margin({Left(0), Top(0), Right(0), Bottom(0)}),
				MainTabPage << Padding({Left(0), Top(0), Right(0), Bottom(0)}),
				MainTabPage << Text Color(2147483647), MainTabPage << UI Only(0),
				MainTabPage << Vertical Alignment("Default"), MainTabPage << Visibility("Visible"),
				MainTabPage << Set Min Size(717, 333), MainTabPage << Set Max Size(30000, 30000),
				MainTabPage << Set Stretch({"Neutral", "Neutral"}), MainTabPage << Title("Dashboard"),
				MainTabPage << Tip(""), MainTabPage << Icon(""), MainTabPage << Closeable(0),
				MainTabPage << Moveable(0), MainTabPage << Set Base Font("Text"),
				MainTabPage << Set Font Scale(1), Splitter1 << Background Color(2147483647),
				Splitter1 << Border({Left(0), Top(0), Right(0), Bottom(0)}), Splitter1 << Enabled(1),
				Splitter1 << Horizontal Alignment("Default"),
				Splitter1 << Margin({Left(0), Top(0), Right(0), Bottom(0)}),
				Splitter1 << Padding({Left(0), Top(0), Right(0), Bottom(0)}),
				Splitter1 << Text Color(2147483647), Splitter1 << UI Only(0),
				Splitter1 << Vertical Alignment("Default"), Splitter1 << Visibility("Visible"),
				Splitter1 << Dockable(1), Splitter1 << Set Width(821), Splitter1 << Set Height(454),
				Splitter1 << Set Sizes({0.69682151589242, 0.30317848410758}),
				Splitter1 << Set Min Size(725, 382), Splitter1 << Set Max Size(120009, 60003),
				Splitter1 << Set Stretch({"Window", "Window"}), Splitter1 << set horizontal(1),
				DataFilterSource1 << Background Color(2147483647),
				DataFilterSource1 << Border({Left(0), Top(0), Right(0), Bottom(0)}),
				DataFilterSource1 << Enabled(1), DataFilterSource1 << Horizontal Alignment("Default"),
				DataFilterSource1 << Margin({Left(0), Top(0), Right(0), Bottom(0)}),
				DataFilterSource1 << Padding({Left(0), Top(0), Right(0), Bottom(0)}),
				DataFilterSource1 << Text Color(2147483647), DataFilterSource1 << UI Only(0),
				DataFilterSource1 << Vertical Alignment("Default"), DataFilterSource1 << Visibility("Visible"),
				DataFilterSource1 << Set Min Size(642, 307), DataFilterSource1 << Set Max Size(90006, 60003),
				DataFilterSource1 << Set Stretch({"Neutral", "Neutral"}),
				Splitter2 << Background Color(2147483647),
				Splitter2 << Border({Left(0), Top(0), Right(0), Bottom(0)}), Splitter2 << Enabled(1),
				Splitter2 << Horizontal Alignment("Default"),
				Splitter2 << Margin({Left(0), Top(0), Right(0), Bottom(0)}),
				Splitter2 << Padding({Left(0), Top(0), Right(0), Bottom(0)}),
				Splitter2 << Text Color(2147483647), Splitter2 << UI Only(0),
				Splitter2 << Vertical Alignment("Default"), Splitter2 << Visibility("Visible"),
				Splitter2 << Dockable(0), Splitter2 << Set Width(642), Splitter2 << Set Height(553),
				Splitter2 << Set Sizes({0.526431718061674, 0.473568281938326}),
				Splitter2 << Set Min Size(642, 307), Splitter2 << Set Max Size(90006, 60003),
				Splitter2 << Set Stretch({"Window", "Window"}), Splitter2 << set horizontal(0),
				TabPage2 << Background Color(2147483647),
				TabPage2 << Border({Left(0), Top(0), Right(0), Bottom(0)}), TabPage2 << Enabled(1),
				TabPage2 << Horizontal Alignment("Default"),
				TabPage2 << Margin({Left(0), Top(0), Right(0), Bottom(0)}),
				TabPage2 << Padding({Left(0), Top(0), Right(0), Bottom(0)}),
				TabPage2 << Text Color(2147483647), TabPage2 << UI Only(0),
				TabPage2 << Vertical Alignment("Default"), TabPage2 << Visibility("Visible"),
				TabPage2 << Set Min Size(195, 137), TabPage2 << Set Max Size(30000, 30000),
				TabPage2 << Set Stretch({"Neutral", "Neutral"}), TabPage2 << Title("Graph Builder"),
				TabPage2 << Tip(""), TabPage2 << Icon("Trellis"), TabPage2 << Closeable(1),
				TabPage2 << Moveable(1), TabPage2 << Set Base Font("Text"), TabPage2 << Set Font Scale(1),
				Scroll2 << Background Color(2147483647),
				Scroll2 << Border({Left(0), Top(0), Right(0), Bottom(0)}), Scroll2 << Enabled(1),
				Scroll2 << Horizontal Alignment("Default"),
				Scroll2 << Margin({Left(0), Top(0), Right(0), Bottom(0)}),
				Scroll2 << Padding({Left(0), Top(0), Right(0), Bottom(0)}), Scroll2 << Text Color(2147483647),
				Scroll2 << UI Only(0), Scroll2 << Username Resizable({1, 1}),
				Scroll2 << Vertical Alignment("Default"), Scroll2 << Visibility("Visible"),
				Scroll2 << Set Min Size(195, 111), Scroll2 << Set Max Size(30095, 30001),
				Scroll2 << Set Stretch({"Window", "Window"}), Scroll2 << Width(642), Scroll2 << Height(263),
				Scroll2 << Set Auto Scrollable(1), Scroll2 << Set Scrollers(0, 0),
				Scroll2 << Set Show Empty(0), Scroll2 << Set Clip Printing(0),
				Report2 << Background Color(2147483647),
				Report2 << Border({Left(0), Top(0), Right(0), Bottom(0)}), Report2 << Enabled(1),
				Report2 << Horizontal Alignment("Default"),
				Report2 << Margin({Left(0), Top(0), Right(0), Bottom(0)}),
				Report2 << Padding({Left(0), Top(0), Right(0), Bottom(0)}), Report2 << Text Color(2147483647),
				Report2 << UI Only(0), Report2 << Vertical Alignment("Default"),
				Report2 << Visibility("Visible"), Report2 << Set Min Size(195, 111),
				Report2 << Set Max Size(30095, 30001), Report2 << Set Stretch({"Neutral", "Neutral"}),
				Report2 << set horizontal(0), DataFilterSource2 << Background Color(2147483647),
				DataFilterSource2 << Border({Left(0), Top(0), Right(0), Bottom(0)}),
				DataFilterSource2 << Enabled(1), DataFilterSource2 << Horizontal Alignment("Default"),
				DataFilterSource2 << Margin({Left(0), Top(0), Right(0), Bottom(0)}),
				DataFilterSource2 << Padding({Left(0), Top(0), Right(0), Bottom(0)}),
				DataFilterSource2 << Text Color(2147483647), DataFilterSource2 << UI Only(0),
				DataFilterSource2 << Vertical Alignment("Default"), DataFilterSource2 << Visibility("Visible"),
				DataFilterSource2 << Set Min Size(642, 167), DataFilterSource2 << Set Max Size(90006, 30000),
				DataFilterSource2 << Set Stretch({"Neutral", "Neutral"}),
				Splitter8 << Background Color(2147483647),
				Splitter8 << Border({Left(0), Top(0), Right(0), Bottom(0)}), Splitter8 << Enabled(1),
				Splitter8 << Horizontal Alignment("Default"),
				Splitter8 << Margin({Left(0), Top(0), Right(0), Bottom(0)}),
				Splitter8 << Padding({Left(0), Top(0), Right(0), Bottom(0)}),
				Splitter8 << Text Color(2147483647), Splitter8 << UI Only(0),
				Splitter8 << Vertical Alignment("Default"), Splitter8 << Visibility("Visible"),
				Splitter8 << Dockable(1), Splitter8 << Set Width(642), Splitter8 << Set Height(261),
				Splitter8 << Set Sizes({0.36331569664903, 0.63668430335097}),
				Splitter8 << Set Min Size(642, 167), Splitter8 << Set Max Size(90006, 30000),
				Splitter8 << Set Stretch({"Window", "Window"}), Splitter8 << set horizontal(1),
				TabPage3 << Background Color(2147483647),
				TabPage3 << Border({Left(0), Top(0), Right(0), Bottom(0)}), TabPage3 << Enabled(1),
				TabPage3 << Horizontal Alignment("Default"),
				TabPage3 << Margin({Left(0), Top(0), Right(0), Bottom(0)}),
				TabPage3 << Padding({Left(0), Top(0), Right(0), Bottom(0)}),
				TabPage3 << Text Color(2147483647), TabPage3 << UI Only(0),
				TabPage3 << Vertical Alignment("Default"), TabPage3 << Visibility("Visible"),
				TabPage3 << Set Min Size(205, 102), TabPage3 << Set Max Size(30000, 30000),
				TabPage3 << Set Stretch({"Neutral", "Neutral"}), TabPage3 << Title("Graph Builder"),
				TabPage3 << Tip(""), TabPage3 << Icon("Trellis"), TabPage3 << Closeable(1),
				TabPage3 << Moveable(1), TabPage3 << Set Base Font("Text"), TabPage3 << Set Font Scale(1),
				Scroll3 << Background Color(2147483647),
				Scroll3 << Border({Left(0), Top(0), Right(0), Bottom(0)}), Scroll3 << Enabled(1),
				Scroll3 << Horizontal Alignment("Default"),
				Scroll3 << Margin({Left(0), Top(0), Right(0), Bottom(0)}),
				Scroll3 << Padding({Left(0), Top(0), Right(0), Bottom(0)}), Scroll3 << Text Color(2147483647),
				Scroll3 << UI Only(0), Scroll3 << Username Resizable({1, 1}),
				Scroll3 << Vertical Alignment("Default"), Scroll3 << Visibility("Visible"),
				Scroll3 << Set Min Size(205, 76), Scroll3 << Set Max Size(30105, 30001),
				Scroll3 << Set Stretch({"Window", "Window"}), Scroll3 << Width(205), Scroll3 << Height(235),
				Scroll3 << Set Auto Scrollable(1), Scroll3 << Set Scrollers(0, 0),
				Scroll3 << Set Show Empty(0), Scroll3 << Set Clip Printing(0),
				Report3 << Background Color(2147483647),
				Report3 << Border({Left(0), Top(0), Right(0), Bottom(0)}), Report3 << Enabled(1),
				Report3 << Horizontal Alignment("Default"),
				Report3 << Margin({Left(0), Top(0), Right(0), Bottom(0)}),
				Report3 << Padding({Left(0), Top(0), Right(0), Bottom(0)}), Report3 << Text Color(2147483647),
				Report3 << UI Only(0), Report3 << Vertical Alignment("Default"),
				Report3 << Visibility("Visible"), Report3 << Set Min Size(205, 76),
				Report3 << Set Max Size(30105, 30001), Report3 << Set Stretch({"Neutral", "Neutral"}),
				Report3 << set horizontal(0), Splitter4 << Background Color(2147483647),
				Splitter4 << Border({Left(0), Top(0), Right(0), Bottom(0)}), Splitter4 << Enabled(1),
				Splitter4 << Horizontal Alignment("Default"),
				Splitter4 << Margin({Left(0), Top(0), Right(0), Bottom(0)}),
				Splitter4 << Padding({Left(0), Top(0), Right(0), Bottom(0)}),
				Splitter4 << Text Color(2147483647), Splitter4 << UI Only(0),
				Splitter4 << Vertical Alignment("Default"), Splitter4 << Visibility("Visible"),
				Splitter4 << Dockable(1), Splitter4 << Set Width(434), Splitter4 << Set Height(261),
				Splitter4 << Set Sizes({0.587006960556845, 0.412993039443155}),
				Splitter4 << Set Min Size(434, 167), Splitter4 << Set Max Size(60003, 30000),
				Splitter4 << Set Stretch({"Window", "Window"}), Splitter4 << set horizontal(1),
				TabPage4 << Background Color(2147483647),
				TabPage4 << Border({Left(0), Top(0), Right(0), Bottom(0)}), TabPage4 << Enabled(1),
				TabPage4 << Horizontal Alignment("Default"),
				TabPage4 << Margin({Left(0), Top(0), Right(0), Bottom(0)}),
				TabPage4 << Padding({Left(0), Top(0), Right(0), Bottom(0)}),
				TabPage4 << Text Color(2147483647), TabPage4 << UI Only(0),
				TabPage4 << Vertical Alignment("Default"), TabPage4 << Visibility("Visible"),
				TabPage4 << Set Min Size(253, 167), TabPage4 << Set Max Size(30000, 30000),
				TabPage4 << Set Stretch({"Neutral", "Neutral"}), TabPage4 << Title("Graph Builder"),
				TabPage4 << Tip(""), TabPage4 << Icon("Trellis"), TabPage4 << Closeable(1),
				TabPage4 << Moveable(1), TabPage4 << Set Base Font("Text"), TabPage4 << Set Font Scale(1),
				Scroll4 << Background Color(2147483647),
				Scroll4 << Border({Left(0), Top(0), Right(0), Bottom(0)}), Scroll4 << Enabled(1),
				Scroll4 << Horizontal Alignment("Default"),
				Scroll4 << Margin({Left(0), Top(0), Right(0), Bottom(0)}),
				Scroll4 << Padding({Left(0), Top(0), Right(0), Bottom(0)}), Scroll4 << Text Color(2147483647),
				Scroll4 << UI Only(0), Scroll4 << Username Resizable({1, 1}),
				Scroll4 << Vertical Alignment("Default"), Scroll4 << Visibility("Visible"),
				Scroll4 << Set Min Size(253, 141), Scroll4 << Set Max Size(30153, 30001),
				Scroll4 << Set Stretch({"Window", "Window"}), Scroll4 << Width(253), Scroll4 << Height(235),
				Scroll4 << Set Auto Scrollable(1), Scroll4 << Set Scrollers(0, 0),
				Scroll4 << Set Show Empty(0), Scroll4 << Set Clip Printing(0),
				Report4 << Background Color(2147483647),
				Report4 << Border({Left(0), Top(0), Right(0), Bottom(0)}), Report4 << Enabled(1),
				Report4 << Horizontal Alignment("Default"),
				Report4 << Margin({Left(0), Top(0), Right(0), Bottom(0)}),
				Report4 << Padding({Left(0), Top(0), Right(0), Bottom(0)}), Report4 << Text Color(2147483647),
				Report4 << UI Only(0), Report4 << Vertical Alignment("Default"),
				Report4 << Visibility("Visible"), Report4 << Set Min Size(253, 141),
				Report4 << Set Max Size(30153, 30001), Report4 << Set Stretch({"Neutral", "Neutral"}),
				Report4 << set horizontal(0), TabPage5 << Background Color(2147483647),
				TabPage5 << Border({Left(0), Top(0), Right(0), Bottom(0)}), TabPage5 << Enabled(1),
				TabPage5 << Horizontal Alignment("Default"),
				TabPage5 << Margin({Left(0), Top(0), Right(0), Bottom(0)}),
				TabPage5 << Padding({Left(0), Top(0), Right(0), Bottom(0)}),
				TabPage5 << Text Color(2147483647), TabPage5 << UI Only(0),
				TabPage5 << Vertical Alignment("Default"), TabPage5 << Visibility("Visible"),
				TabPage5 << Set Min Size(178, 102), TabPage5 << Set Max Size(30000, 30000),
				TabPage5 << Set Stretch({"Neutral", "Neutral"}), TabPage5 << Title("Graph Builder"),
				TabPage5 << Tip(""), TabPage5 << Icon("Trellis"), TabPage5 << Closeable(1),
				TabPage5 << Moveable(1), TabPage5 << Set Base Font("Text"), TabPage5 << Set Font Scale(1),
				Scroll5 << Background Color(2147483647),
				Scroll5 << Border({Left(0), Top(0), Right(0), Bottom(0)}), Scroll5 << Enabled(1),
				Scroll5 << Horizontal Alignment("Default"),
				Scroll5 << Margin({Left(0), Top(0), Right(0), Bottom(0)}),
				Scroll5 << Padding({Left(0), Top(0), Right(0), Bottom(0)}), Scroll5 << Text Color(2147483647),
				Scroll5 << UI Only(0), Scroll5 << Username Resizable({1, 1}),
				Scroll5 << Vertical Alignment("Default"), Scroll5 << Visibility("Visible"),
				Scroll5 << Set Min Size(178, 76), Scroll5 << Set Max Size(30078, 30001),
				Scroll5 << Set Stretch({"Window", "Window"}), Scroll5 << Width(178), Scroll5 << Height(235),
				Scroll5 << Set Auto Scrollable(1), Scroll5 << Set Scrollers(0, 0),
				Scroll5 << Set Show Empty(0), Scroll5 << Set Clip Printing(0),
				Report5 << Background Color(2147483647),
				Report5 << Border({Left(0), Top(0), Right(0), Bottom(0)}), Report5 << Enabled(1),
				Report5 << Horizontal Alignment("Default"),
				Report5 << Margin({Left(0), Top(0), Right(0), Bottom(0)}),
				Report5 << Padding({Left(0), Top(0), Right(0), Bottom(0)}), Report5 << Text Color(2147483647),
				Report5 << UI Only(0), Report5 << Vertical Alignment("Default"),
				Report5 << Visibility("Visible"), Report5 << Set Min Size(178, 76),
				Report5 << Set Max Size(30078, 30001), Report5 << Set Stretch({"Neutral", "Neutral"}),
				Report5 << set horizontal(0), TabPage1 << Background Color(2147483647),
				TabPage1 << Border({Left(0), Top(0), Right(0), Bottom(0)}), TabPage1 << Enabled(1),
				TabPage1 << Horizontal Alignment("Default"),
				TabPage1 << Margin({Left(0), Top(0), Right(0), Bottom(0)}),
				TabPage1 << Padding({Left(0), Top(0), Right(0), Bottom(0)}),
				TabPage1 << Text Color(2147483647), TabPage1 << UI Only(0),
				TabPage1 << Vertical Alignment("Default"), TabPage1 << Visibility("Visible"),
				TabPage1 << Set Min Size(72, 62), TabPage1 << Set Max Size(30000, 30000),
				TabPage1 << Set Stretch({"Neutral", "Neutral"}),
				TabPage1 << Title("Text Explorer for Comment"), TabPage1 << Tip(""),
				TabPage1 << Icon("TextAnalysis"), TabPage1 << Closeable(1), TabPage1 << Moveable(1),
				TabPage1 << Set Base Font("Text"), TabPage1 << Set Font Scale(1),
				Scroll1 << Background Color(2147483647),
				Scroll1 << Border({Left(0), Top(0), Right(0), Bottom(0)}), Scroll1 << Enabled(1),
				Scroll1 << Horizontal Alignment("Default"),
				Scroll1 << Margin({Left(0), Top(0), Right(0), Bottom(0)}),
				Scroll1 << Padding({Left(0), Top(0), Right(0), Bottom(0)}), Scroll1 << Text Color(2147483647),
				Scroll1 << UI Only(0), Scroll1 << Username Resizable({1, 1}),
				Scroll1 << Vertical Alignment("Default"), Scroll1 << Visibility("Visible"),
				Scroll1 << Set Min Size(72, 36), Scroll1 << Set Max Size(30000, 30000),
				Scroll1 << Set Stretch({"Window", "Window"}), Scroll1 << Width(635), Scroll1 << Height(527),
				Scroll1 << Set Auto Scrollable(1), Scroll1 << Set Scrollers(1, 1),
				Scroll1 << Set Show Empty(0), Scroll1 << Set Clip Printing(0),
				Report1 << Background Color(2147483647),
				Report1 << Border({Left(0), Top(0), Right(0), Bottom(0)}), Report1 << Enabled(1),
				Report1 << Horizontal Alignment("Default"),
				Report1 << Margin({Left(0), Top(0), Right(0), Bottom(0)}),
				Report1 << Padding({Left(0), Top(0), Right(0), Bottom(0)}), Report1 << Text Color(2147483647),
				Report1 << UI Only(0), Report1 << Vertical Alignment("Default"),
				Report1 << Visibility("Visible"), Report1 << Set Min Size(622, 870),
				Report1 << Set Max Size(622, 870), Report1 << Set Stretch({"Neutral", "Neutral"}),
				Report1 << set horizontal(0)
	Initialize(
		Module1 << Auto Launch(1);
		Module1 << Set Module Type("Report");
		Module1 << Set Window Title("^TABLENAME - ^APPNAME");
) << Run;
JMPApp[Dashboard]
Hover Label: Preset library found at /C:/Program Files/SAS/JMP/16/Resources/Builtins/hllib.jsl
// Close Data Table: Press Ganey data
Close( "Press Ganey data" );
JMP App(
	Auto Launch(1),
	Snap To Grid(1),
	Show Grid(1),
	Show Properties(0),
	Show Sources(0),
	Dashboard Mode(1),
	Parameters,
	Tables(
			Set Path(
			Invisible(0),
			Set Script(
				Open(
					"$DOWNLOADS/Copy of PG Medical Practice Comments Jan-Mar 2023 for UserName.xlsx",
					Worksheet Settings(
						1,
	Thumbnail(
		New Image(
			Char To Blob(
				"base64compressed"
			"png"
	Allocate(
		Module1 = Plan(
			PreAllocate,
			Allocate(
				Report2 = Platform(
					DataTable1,
					Graph Builder(
						Size(547, 262),
							Dispatch(
								"400",
								ScaleBox,
								{Legend Model(
									2,
				Report3 = Platform(
					DataTable1,
					Graph Builder(
						Size(100, 234),
				Report4 = Platform(
					DataTable1,
					Graph Builder(
						Size(100, 234),
							Dispatch(
								"400",
								ScaleBox,
								{Legend Model(
									2,
									Properties(
										0,
										Item ID("5", 1)
									Properties(
										1,
										Item ID("6", 1)
									Properties(
										2,
										Item ID("7", 1)
									Properties(
										3,
										Item ID("8", 1)
									Properties(
										4,
										Item ID("9", 1)
									Properties(
										5,
									Properties(
										-1,
										Item ID("", 1)
									Properties(
										-1,
									Properties(
										-1,
										Item ID("1", 1)
									Properties(
										-1,
										Item ID("2", 1)
									Properties(
										-1,
										Item ID("3", 1)
									Properties(
										-1,
										Item ID("4", 1)
							Dispatch(
								"Graph Builder",
								FrameBox,
				Report5 = Platform(
					DataTable1,
					Graph Builder(
						Size(100, 234),
				Report1 = Platform(
					DataTable1,
					Text Explorer(
						Set Regex(
							Library("Money"),
							Library("Words"),
							Library("Time"),
							Library("Numbers"),
						Show Word Cloud(1),
						Layout("Centered"),
						Language("English")
			Organize(
			Initialize(
	Initialize(
) << Run;
JMPApp[Dashboard]
// Clear row selection
Data Table( "Press Ganey data" ) << Clear Select;
Hover label filter generation doesn't support selection filters, skipping.
Re: "This feature is not interactive"
Hi @Username01 ,
Interactive HTML supports a subset of the features of JMP. When your graphs or dashboards use features not supported, you should be able to look at the log (View > Log) to see messages describing the unsupported features when you export to Interactive HTML.
I can't easily tell from your JSL code all the features that are not supported, but at a quick glance I can see that you are trying to use selection filters that are not supported in Interactive HTML. You are also using more than one local data filter. Only the first one is supported.
You may be able to work around some of the limitations, but if you would like some help in doing so, please work with JMP Technical support, unless you are comfortable sharing more details here, and I will try to help.
~John
