"Replace missing with previous value" for multiple column selection on JMP19
Previous versions of JMP would let users select multiple columns and use the "Replace missing with previous value" option from the right-click drop-down menu, applying the function to all columns selected. With JMP19, I can only do it if I select one column at a time. Is there a way to keep doing with with multiple columns selected?
0 REPLIES 0
