Gera
"Next in hierarchy" column property seems to be missing
I looked at some videos and help files on graphlets and saw references to the "Next in hierarchy" column property. However, I do not see this in my column properties. In videos, it seemed to be at the bottom of the properties list. I am using JMP 16.2.
Thank you
columnproperties.jpgties lists. I am using JMP16.2.
Re: "Next in hierarchy" column property seems to be missing
Hi @Gera ,
This is a known issue with JMP 16.2. If you can use JMP Pro 16.2 or JMP 17, you can see this column property.
Hi @Gera ,
Gera
Thank you. Just waiting on IT to get JMP17 deployed...Hopefully will get it soon.
