SabrinaP
python code
I need the following file if someone can share it with me as I no longer have access to my installation package. If someone can kindly send it to me : sabrina.piedimonte@uhn.ca
I need this pacakge: jmp_score.py
found in: The file jmp_score.py that is needed to run your Python scoring application can be found in the Scoring/Python folder in your JMP installation folder. When deploying your models, copy jmp_score.py to the same location as your executable scoring code.
thanks!
Sabrina
6 REPLIES 6
Re: python code
If you are still a licensed JMP user, you can contact JMP support and I am sure they will be able to help you out. If you are not a licensed JMP user, I do not see in the jmp_score.py any reference to this code being available to the public domain, so licensed JMP users should not send a copy.
SabrinaP
Re: python code
thanks,
I do have a JMP license however i cannot find it in my files
Re: python code
Contact jmp support and they will help you
Re: python code
Hi Jim, I realize that this is an old post but I thought maybe you could help me. I'm trying to find out how I can install the jmp_score python package.
When I copy Formula Depo Python code into a python file outside of JMP, the first thing it tells me, of course, is that it cannot import jmp_score as jmp, since I don't have it installed. I've tried looking for it online, but have found little useful information on it. Would you please be able to point me in the right direction?
All the best,
A
Re: python code
I am not the correct person to deal with your issue.  I would wait a day or so, and if another Community Member does not provide you with the answer, then I would contact JMP Support directly.
Byron_JMP
Re: python code
On a Mac, the default path is:
/Library/Application Support/JMP/17/scoring/Python/jmp_score.py
