Igarashi31
propensity scoreを用いたIPTW
有料のJMP17.0.0ベース版のユーザーです。傾向スコアを用いたIPTWを行いたいと考えていますが、アドインは存在しますか?存在するのであれば、どちらからダウンロードできますか?よろしくお願いします。
Re: propensity scoreを用いたIPTW
propensity score IPTW might be a good read
Igarashi31
Upon further investigation, it appears that causal inference is supported in JMP Pro 19. I would appreciate it if anyone could confirm whether similar functionality is available in the standard version of JMP as well.
Most likely it is only JMP Pro feature Fitting Linear Models > Causal Treatment Models as it has the JMP Pro icon.
