KC08
Scatterplot that supports data from 2 files
Im looking for different ways to validate block model estimates against the composites values. I use numerous methods but would like to add a scatterplot validation. Is it possible that there is a plot that allows me to use 2 fields from 2 files or would i have to modify 1 file to contain both?
much appreciated
Re: Scatterplot that supports data from 2 files
Unless specifically designed to use multiple data tables, JMP Platforms, i.e Graph Builder requires the data to be graphed needs to reside in one data table.  Jarmo's suggestion is a solution that will work because a Virtually joined data table looks like a single data table to a JMP Platform.
Unless the data tables are very large, I find that in JMP joining two data tables into one data table is such a simple and often used methodology, that I almost always just join the two data tables together.
