Françoise
probleme import date excel
bonjour,
je n'arrive pas à avoir le bon format dans JMP (d/m/y) comme dans excel et après plusieurs essais, j'ai toujours dans JMP: m/d/y.
merci pour votre aide
hcarr01
Re: probleme import date excel
Maybe you can use the following script :
Names default to here(1);
clear log();
clear symbols();
clear globals();
path = use your correct path...
// Importer un fichier Excel : essai date.xlsx
// → Data Table( "Feuil1" )
Open(
	path,
	Worksheets( "Feuil1" ),
	Use for all sheets( 1 ),
	Concatenate Worksheets( 0 ),
	Worksheet Settings(
		1,
		Has Column Headers( 1 ),
		Number of Rows in Headers( 4 ),
		Headers Start on Row( 1 ),
		Data Starts on Row( 5 ),
		Data Starts on Column( 1 ),
		Data Ends on Row( 0 ),
		Data Ends on Column( 0 ),
		Replicated Spanned Rows( 1 ),
		Suppress Hidden Rows( 1 ),
		Suppress Hidden Columns( 1 ),
		Suppress Empty Columns( 0 ),
		Treat as Hierarchy( 0 ),
		Multiple Series Stack( 0 ),
		Import Cell Colors( 0 ),
		Limit Column Detect( 0 ),
		Column Separator String( "-" ),
		Column Numeric Format(
			Index( 0 ),
			Column Name( "Datectrl + ;"n ),
			Datatype( "Character" )
		Column Numeric Format( Index( 7 ), Format( "Best", 9 ) ),
			Index( 11 ),
			Format( "Best", Use thousands separator( 1 ), 9 )
			Index( 12 ),
		Column Numeric Format( Index( 13 ), Datatype( "Character" ) ),
		Column Numeric Format( Index( 14 ), Format( "d/m/y", 10 ) ),
		Column Numeric Format( Index( 15 ), Datatype( "Character" ) )
// Modifier les informations de colonne : Datectrl + ;
Data Table( "Feuil1" ):"Datectrl + ;"n <<
Set Data Type(
	Numeric,
	Format( "Format Pattern", "<DD>/<MM>/<YYYY>", 10 ),
	Input Format( "Format Pattern", "<DD>/<MM>/<YYYY>" )
) << Set Modeling Type( "Continuous" ) << Set Field Width( 12 );
Level XIII
surprising, which version of JMP?
I tried it with JMP18 and JMP19 and without adjusting a setting I got:
Maybe a wrong setting in the (system) preferences?
Françoise
merci à tous pour vos solutions.
j'ai appliqué le script d'importation hcarr01 et c'est OK !
bon week-end
cordialement
Disable "Limit column type detection" so you get your data as character to your JMP table in this case (from this you can more easily set the format as you wish).
Then you can remove extra rows (could be done in import just make sure you still have character data). From this you can start then fixing the format
Generally, Format Pattern is the best way of formatting your character data into dates.
After the data has been correctly formatted into JMP number, you can then change the format as you want to
