hogi
Level XIII
prev sib - how?
I want to get in this display tree from the Axis Box to the TextEditBox:
but with the below code, I get stuck at step 2: going to the previous sibling:
Names Default to Here(1);
gb = dt << Graph Builder(
	Variables( X( :height ), Y( :weight )),
	Elements( Points( X, Y) )
show(start= report(gb)["Graph Builder",AxisBox(1)]);
show(step1 = start << parent());
show(step2 = step1 << Prev Sib()); // -> empty. doesn't work
show(step3 = step2 << child());
Re: prev sib - how?
The Properties Widow does not appear to show all levels of the hierarchy.  The Show Tree Structure window has an additional layer that needs to be traversed to get to the TextBox() you are looking for
I was able to get to the TextBox() with the below modifications to your illistration
show(step2 = step1 << parent());
show(step3 = step2 << Prev Sib());
show(step4 = step3 << child());
show(step5 = step4 << child());
which has the below results
start = Report(gb)["Graph Builder",AxisBox(1)] = DisplayBox[AxisBox];
step1 = start << parent() = DisplayBox[GraphBuilderAxisBox];
step2 = step1 << parent() = DisplayBox[GraphBuilderComponentBox];
step3 = step2 << Prev Sib() = DisplayBox[GraphBuilderComponentBox];
step4 = step3 << child() = DisplayBox[GraphBuilderTitleBox];
step5 = step4 << child() = DisplayBox[TextEditBox];
Re: prev sib - how?
hogi
Level XIII
Re: prev sib - how?
Thank you, Jim :)
