jan_solo
Break/Continue a (nested) outer for loop
If I have 2 nested for-loops, how can I break/continue the outer loop?
example:
for (i=0, i<10, i++,
     for (j=0, j<10, j++,
          // Do stuff
         if ( <condition>,
               // Continue with the next i
          ); // end if
    ); // end inner loop
     // Do some more stuff
); // end outer loop
ron_horne
Re: Break/Continue a (nested) outer for loop
hi Jan,
try to use the Break(). the following script will stop running when i will reach 3.
For( i = 0, i <= 5, i++,
    For( z = 0, z < 5, z++,
    if (i >= 3, Break());
        Print( "i=" || Char( i ) || " & z=" || Char( z ) )
the next script will just skip i=3 and continue to i=4 and i=5.
    if (i== 3, Break());
please take a look at this link for the explanation about the use Break and while:
Iterate
ron
ron_horne
hi Jan,
Iterate
ron
jan_solo
Thank you for the answer.
It's not completely what I am looking for.
Consider this:
    Print ( "OUTER i = " || Char (i));
If I run this script, outer i is printed.  The real problem here is to 'continue with the next i', without the second print-line (OUTER i = ...) will be printed.  Is there an easy way to do, or do I just have to use a boolean 'continueOuterLoop'?
Thanx.
Boolean solution:
    continueOuterLoop = 0;
    if (i== 3, continueOuterLoop = 1; Break(); );
    if (continueOuterLoop == 0,
jwiltsie
Hi Jan, Couldn't you just add an i++ instead of Break() during the inner For loop?
You could also set z=0 after i++, if you wanted it to restart the inner For loop without going into the outer For loop.
For example:
		if (i== 3,
			Print( "i=" || Char( i ) || " & z=" || Char( z ) );
			i++; // I put the i++ after the print so that it prints i=3
