See how to use to use Text Explorer to glean valuable information from text data at April 25 webinar.
posting interactive html plots on websites
abmayfield
    I am interested in putting interactive JMP HTML files on my personal website, which is hosted by Squarespace. It seems like the only way to do this is 1) open the interactive HTML file on Chrome, 2) copy the HTML scripts (using Mac's "Developer" option), and 3) pasting the script into either a code box or "embed" box on my website. This does work (although I always get an error message saying the code is too long). However, it always puts the interactive plot under the footer at the bottom of the page (regardless of where I have "placed" the code box). Is there a way I can modify the script to where it actually puts the interactive plot where I want it to go? Alternatively, is there a way to simply "post" an interactive plot on a website, without the need for scripting? (I know hackers can steal my data this way; this is not a concern of mine. I want people to steal my data since it is for the common good!).
Anderson B. Mayfield
27 REPLIES 27
nascif_jmp
Re: posting interactive html plots on websites
You might have to enable visibility properties in One Drive to get the pages to report the correct MIME type.
It is also possible that Square Space is blocking all foreign pages (or all foreign JavaScript content) for security reasons.
Try creating an iframe pointing to my interactive HTML page on S3. The URL is on my first post.
This way you will know if the issue is with One Drive or SquareSpace.
Also, check your JavaScript console for error messages, you might find a clue there.
abmayfield
Great idea! I don't know why I didn't just simply copy and paste your code before, but YOUR graph comes up on my website fine. There is a long list of complaints about OneDrive's handling of HTML files (they open as script, rather than the final product within OneDrive). I just tried it with Dropbox and had the same problem as with OneDrive. I wonder if it's because, when you share files via a link, the link doesn't look like a regular website link (like yours)?For instance: https://www.dropbox.com/s/dwjyb5n0fk24zoo/Fit%20Y%20by%20X.html?dl=0. Interestingly, there is an "embed" feature with OneDrive that is meant to get around this issue (it gives you HTML code to copy to your website), but, ironically, it doesn't work for interative HTML!
In any event, I have just signed up for an S3 account, and it WORKS! Man, I never thought it would be such a pain to do this, but I think that, thanks to your help, using S3 to host the interactive HTML files from JMP and then referencing the S3 file links is a workable solution. Thanks so much for your help (and to the others, as well).
nascif_jmp
Glad it helped! And don't forget, if you use JMP Pro, you can export your JMP models to scoring code and host them in AWS too:
https://dfd3m9li3aipf.cloudfront.net/index.html
or embed them (as JavaScript scoring code) directly into your HTML dynamic pages:
http://jmp.scoring.iris.s3-website.us-east-2.amazonaws.com/
http://jmp.valentine.s3-website-us-east-1.amazonaws.com/
abmayfield
Awesome! And as a note to other interested individuals: Google Drive also DOES NOT WORK (interactive HTML files cannot be hosted by GoogleDrive and referenced in scripts to appear on websites). I wonder why S3 is the only one of these major clouds that works with interactive HTML (I didn't try Apple's iCloud, though). Shouldn't everyone have already switched over to this language for interactive file types?
My next step is going to be getting a JMP report with multiple windows to appear on my website. I'm guessing it should be no different from a single graph in terms of the steps necessary to do so (provided I use S3).
This request and the responses are awesome! Thanks!
I tried Dropbox, GoogleDrive, and OneDrive before my presentation about sharing Interactive HTML last year and had to report some disappointing findings.
It's good to know there are alternatives that work.
By the way, iFrames work in the JMP Community too!
abmayfield
I wrote a complaint to OneDrive about their inability to handle HTML files. When you "open" an interactive HTML file WITHIN OneDrive, it only shows code!!! You would think Microsoft could handle this task....
I do want to mention here, in case a non-JMP expert/employee stumbles across this post, that the raw data can be extracted from interactive plots (i.e., a hacker could get at your data and reproduce them). I think that, for this reason, there is not currently a large demand for posting these kinds of interactive figures on personal websites (and why this is the first post on this topic). I'm mainly focusing on meta-analyzing already published data, so this is less of an issue for me.
abmayfield
BTW, this is also an "accepted" solution; the reason it did not work for me was because none of my websites or clouds could properly "host" an interactive HTML file. As it turns out, Amazon's S3 server CAN do so, so, upon using your script and providing a link to the interactive JMP HTML plot found on my S3 cloud, the plot appears in the correct location, and I do not need to paste in the 200 pages of script.
AdamChoen
Iframe is not working for me anymore with JMP17 interactive HTML.
appreciate some TSing clues
Thanks, Adam
gail_massari
@John_Powell_JMP  A questions came in that you might be able to answer Adam @AdamChoen  if you @mntion someone they get pinged in email.
Thanks, Adam
@AdamChoen ,
When you open a web page where you've embedded an Interactive HTML page from JMP 17, please check the browser console (right click, Inspect, then choose Console) to see if there any errors reported.
If there are any, please copy them here so I can see what might be going wrong.
Thanks,
~John
