キャンセル
次の結果を表示
表示  限定  | 次の代わりに検索
もしかして:
言語を選択 翻訳バーを非表示
Johnanderson
plot two variables in one axes using fit Y by X
Dear experts, bellow is an example table for what I aim for:
I have the three variables   A, B, and C. A and B are numeric continous and C is numeric ordinal. I would like to fit A and B in Y axes and C in x axes. How can I do it in ftx Y by X? Thanks for any help!
John anderson
1 件の受理された解決策
受理された解決策
KarenC
Re: plot two variables in one axes using fit Y by X
If you use Table>Stack and stack A and B then you will get a table with a column for C, a "Label" column of As and Bs and then a Data column. Now with fit Y by X you can use C as your X and the "Data" column as your Y. The Y now has both the A and B data.
元の投稿で解決策を見る
2件の返信2
KarenC
Johnanderson
Nice! Thank you so much!
John anderson
おすすめの記事
