KST-CPT
Modify summary table
I am trying to modify a summary table.
-The table has been ordered by Sub_name, Substrate_ID and Date in that order.
-I want to search the table and if a Sub_name is a duplicate, a Substrate ID is a duplicate and the dates are within 1 day, then combine those rows.
     -these values are ones that ran through midnight, so their dates are different, which causes them to be on seperate lines.
I tried the following code:
debug = RTDT << Summary(Group( :Sub_name, :Substrate_ID, :Date ),
Mean( :Runtime ),
Freq( "None" ),
Weight( "None" ),
debug << Sort( By(:Sub_name, :Substrate_ID ), Order(Ascending), Replace Table);
EOL = Nrows(debug);
for(i=1, i < (EOL), i++, Formula(
if((debug:Substrate_ID[i+1] == debug:Substrate_ID[i]) &
(debug:Sub_name[i+1] == debug:Sub_name[i]) &
((debug:Date[i+1] - debug:Date[i]) == 86400),
NewCount = :N Rows[i]+:N Rows[i+1];
:N Rows[i+1] = New Count;
NewTime = column(debug|"Mean(Runtime)")[i] + column(debug|"Mean(Runtime)")[i+1];
column(debug|"Mean(Runtime)")[i+1] = NewTime;
debug << slect row(i) << delete row,
Thanks for any help.
Re: Modify summary table
I think you can solve your issue very simply by using the Summary Platform for a second time
dt = Current Data Table();
dt << Summary(
	Group( :Sub_name, :Substrate_ID ),
	Max( :Date ),
	Sum( :N Rows ),
	Sum( :Name( "Mean(Runtime)" ) ),
	Freq( "None" ),
	Weight( "None" ),
	statistics column name format( "column" ),
	Link to original data table( 0 )
dt << Summary(
	Max( :Date ),
	Sum( :N Rows ),
	Freq( "None" ),
	Weight( "None" ),
