Learn how to build custom Python data connectors and further customize JMP’s Data Connector Framework with the Python Data Connector Demo, available now in the JMP Marketplace!
See how to create experiments to support product design and ID useful product features. Register for June 12 webinar, 2pm US Eastern Time.
Please state the percetnile formula being used in JMP tabulate function. I know this is not the same as the formula in excel because they are giving me different result.
I need it badly to justify the JMP application in our system.
JMP quantiles seem to give the same results as the Excel percentile.exc function (found in newer Excel versions). Functions percentile.inc and the (depreciated) percentile can yield different results from JMP.
If you use tabulate you may need to "set format" to display all decimal numbers of the interpolated result.
videodata.push(data[i]);
catch(e){
/* Re compile html */
/* Adding Translation flag */
if (tr_obj.length > 0) {
try {
} catch (e) {
} else {
try {
tr_para.appendChild(tr_fTag);
else {
} else {
} catch (e) {
} else {
// syncList.remove(value);
if (index > -1) {
}else {
if (value == '2959' && "ForumTopicPage" == "TkbArticlePage") {
/* V1.1 Remove from UI */
var sub_L = "";
if(value == '2959') {
}else{
sub_L = newSub.innerHTML;
else{
} else {
try{
catch(e){
if (value == '2959') {
if(subTkbElement){
try {
if(subElement) {
subElement.innerText = sub_L;
} catch (e) {
else {
try {
} catch (e) {
else {
try{
} else {
} else {
catch(e){
} else {
try {
else{
} catch (e) {
// Label translation
if (!labelEle) {
if (labelEle) {
if (listContains) {
trLabels = [];
trLabelsHtml = "";
/* try{
for(var j=0;j,';
trLabelsHtml = trLabelsHtml+'
