statganda
percentile formula
Dear community,
Please state the percetnile formula being used in JMP tabulate function. I know this is not the same as the formula in excel because they are giving me different result.
I need it badly to justify the JMP application in our system.
Thanks
Jeff_Perkinson
Re: percentile formula
Hi statganda,
The process for computing quantiles is found in the Statistical Details for Distribution platform.
Jeff
-Jeff
Jeff_Perkinson
Hi statganda,
Jeff
-Jeff
statganda
Hi Jeff,
This is very useful, because of this i was able to explain to other people logical the JMP formula is.
Thanks
ms
Super User (Alumni) ms
JMP quantiles seem to give the same results as the Excel percentile.exc function (found in newer Excel versions). Functions percentile.inc and the (depreciated) percentile can yield different results from JMP.
If you use tabulate you may need to "set format" to display all decimal numbers of the interpolated result.
