rahulsmils
passing variables to variability chart
Hi all,
I am new to jmp. So please overlook syntax.
I am trying to plot a variability chart as below:
Variability Chart(
       X( :age :height :gender ),
age, gender , height are data columns
I want to make arguments to X variable and store it separately.
Something like declaring first
Xarg_list=[:age :height :gender ]
and then using:
Variability Chart(
       X=Xargs_list;
So If I want to add new column of weight or delete any column in list of arguments I just need to change Xargs_list
Xarg_list=[:age :height :gender :weight];
Any help with forming correct syntax is welcome.
Thanks
12 REPLIES 12
wu
wu
Re: passing variables to variability chart
Thanks.
Could you understand how this script works:
(r << xpath("//IfBox/OutlineBox")) << delete;
The xPath() function is described in the Scripting Index
     Help==>Scripting Index...........search for xpath
But in @ms example, the xPath() function looks through all of the display output to find all of the examples where an IfBox() is followed by an OutlineBox(), and returns all found examples, to which the <<delete message is passed to them, and that closes the Outline Boxes.  Look into the Scripting Guide for information on how to work with the Display Tree output in JMP
     Help==>Books==>Scripting Guide
wu
wu
How to pass a variable value to the char option of
x=1; Std Dev Chart( x );
Thanks.
