rahulsmils
passing variables to variability chart
Hi all,
I am new to jmp. So please overlook syntax.
I am trying to plot a variability chart as below:
Variability Chart(
       X( :age :height :gender ),
age, gender , height are data columns
I want to make arguments to X variable and store it separately.
Something like declaring first
Xarg_list=[:age :height :gender ]
and then using:
Variability Chart(
       X=Xargs_list;
So If I want to add new column of weight or delete any column in list of arguments I just need to change Xargs_list
Xarg_list=[:age :height :gender :weight];
Any help with forming correct syntax is welcome.
Thanks
Re: passing variables to variability chart
Here is an example that provides the functionality you are seeking.
xlist = {"age", "sex"};
dt << Variability Chart(
       Y( :height, :weight ),
       X( Eval( xlist ) ),
       Max Iter( 100 ),
       Conv Limit( 0.00000001 ),
       Number Integration Abscissas( 128 ),
       Number Function Evals( 65536 ),
       Analysis Type( "Choose best analysis (EMS REML Bayesian)" ),
       Std Dev Chart( 1 )
It appears that you are not aware that you can get JMP to produce the scripts that you desire, by just interactively running the platform you want, and then clicking on the red triangle and go to "Script" and to request to save the script to the Script Window.  It gives you a leg up in creating your scripts.
12 REPLIES 12
       X( Eval( xlist ) ),
       Max Iter( 100 ),
       Std Dev Chart( 1 )
rahulsmils
Thanks, actually i figured out a way to do this by grouping columns into a column group first and then using get column group command to get the items.
However there when doing get column groups the order of columns changed from my original assignment.
I will try this one to see if it retains order.
Thanks !
Trung
hi Jim,
can you help me to figure out the concern below?
I have 2 data table: table 1 and table 2
i want to run script variability chart for table 2, but need to have variable to get value from table 1,
below is the example script detail, but it doest not work, please help to review and correct it
A={};
Open(table1);
A[i]=column name(i); // want to use A[i] as variable to get value from table 1 ( for for loop to get)
Open(table2);
Variability Chart(
Y(show(A)),    // this one does NOT work, please help
X( :Product, :Mequip, :Source_Lot, :lot_id ))
thanks,
regards,
Trung
Trung,
The Show() function displays values to the log window.  It does not place the values into the JSL code.  I believe what you want is to use the Eval() function to evaluate the elements in the list "A".
     Eval( A )
Trung
hi Jim,
thanks for your prompt feedback,
i try to take simple script as below but it still doest not work, please advise more
A=column name(13);
New window("my report", obj = context box(
Variability Chart(
Y(eval(A)),   // not come out with exact text "
//it is okay if i change as below
Variability Chart(
Y(:column name(13)),   //  it is working
Trung,
The reason the Eval() did not work, is that you changed the structure of your code.  In your first example, you placed the column name into a list:
A = {};
A[i] = Column Name(i);
In your second version of the code, you changed the variable "A" to a scaler variable
A=column name(13);
Please take the time to read the Scripting Guide, so you can discover the different code structures within JSL, and how to implement them.  It will make your path into JSL much easier and faster.
     Help==>Books==>Scripting Guide
Trung
thanks Jim, i just figured out why it did work,
below is the mistake
Variability Chart(
Y(eval(A[i])),  // A[i] is not work
thank you for your advice, i am just new to JMP too, i will learn more on  Scripting Guide.
thank you very much.
Best regards,
Trung
wu
wu
Appreciate if you advise the following two questions:
(1). In the following of Bivariate plot, the line By(eval(bylist[2])), didn't work;
how to go around by uisng dynamic variables?
(2). I used lines: r=obj<<report; r[outlinebox(3)]<<close all like this;
      To minimized the outlinebox, is there way to remove them from the plots, so the Bivariate plot only showed plots without other outlineboxes.
Thanks.
xy_list = {"weight","height"};
bylist={"sex","age"};
groupbylist={"sex"};
obj=dt << Fit Group(Bivariate(
Y(Eval(xy_list[2] )),
X(Eval(xy_list[1])),
By(eval(bylist[2])); // this line didn't work, has to use By(:age);
Group by(eval (bylist)),
Fit Spline(0.1,Standardized, {Line Width(3)}),
Std Dev Chart(0 ),
Dispatch(
"Bivar Plot",
FrameBox,{Framesize( 200, 200 ),YAxis( Show Major Grid ),
Row Legend(:sex,Color(1), Color Theme("JMP Default"),Marker(0), Marker Theme(""),
Continuous Scale(0), Reverse Scale(0), Excluded Rows(0))})
),Show Points( 1 )
),<<{Arrange in Rows(4)},);
r=obj<<report;
ms
Super User (Alumni) ms
1) It should work as is with comma instead of semicolon after By(...) argument.
2) Try this to delete all outlineboxes except the ones holding the graphs
(r << xpath("//IfBox/OutlineBox")) << delete;
