hallef18
over lay plot
I've graphed why data sets. I'm trying to overlay them using graph builder so I can manipulate / scale the axis but I'm only able to figure out how to stack (or over lay using Graph->Legacy->Overlay which doesn't let me manipulate the axis like I'd like). Any Ideas?
Re: over lay plot
Ah......I didn't pick up on the fact that you wanted the graphs to be on top of each other.  What you need to do for that, is to drag both Y variables to the Y drop area at the same time, or drag one and then the other to the center of the Y drop area.  Then right click on the Y axis and select "Move Right" to move one of the axes to the right side of the graph.  Then you will be able to adjust the 2 axes independently.
Re: over lay plot
Go directly to Graph Builder.
Drag Voltage to the X axis
Drag Ideal J to the Y axis
Drag I to the bottom of the Y axis
To change the Ideal J axis, move to the Y axis for the axis for the values for the Ideal J on the graph, and right click.  Select Axis Settings, and the values set will be changed only for the Ideal J values.
Repeat the same for the I values
The image you attached appears to be what you need to do.  Just move to the Y axis area you want to change, right click, select Axis Settings, and make the changes.
hallef18
Re: over lay plot
hmm Im a bit confused. I was able to drag the axis's but that scaled. It didn't overlay the graphs on top of each other. Did I miss understand?
Re: over lay plot
