Discovery Summit 2026: Early User Edition - September 23-24.Register. It's free.
See how to design an experiment, explore factor-response relationships, assess tradeoffs, and ID best settings. Register for Sep. 11 Mastering JMP.
I am trying to calculate tolerance interval. However, my data is not normal so I selected nonparametric method bu it gives me an error "Unable to calculate this tolerance interval". Do I need to select some other option to use non-parametric method?
The new warning message you see starting with JMP 15.0 gives more information and says, "Unable to calculate this tolerance interval with given sample size, confidence level, and coverage proportion." Additionally, more information on how to get ad adequate sample size for your nonparametric tolerance interval is found in the statistical details in the JMP help. See https://www.jmp.com/support/help/en/15.1/index.shtml#page/jmp/tolerance-intervals-2.shtml#ww1685553.
videodata.push(data[i]);
catch(e){
/* Re compile html */
/* Adding Translation flag */
if (tr_obj.length > 0) {
try {
} catch (e) {
} else {
try {
tr_para.appendChild(tr_fTag);
else {
} else {
} catch (e) {
} else {
// syncList.remove(value);
if (index > -1) {
}else {
if (value == '213357' && "ForumTopicPage" == "TkbArticlePage") {
/* V1.1 Remove from UI */
var sub_L = "";
if(value == '213357') {
}else{
sub_L = newSub.innerHTML;
else{
} else {
try{
catch(e){
if (value == '213357') {
if(subTkbElement){
try {
if(subElement) {
subElement.innerText = sub_L;
} catch (e) {
else {
try {
} catch (e) {
else {
try{
} else {
} else {
catch(e){
} else {
try {
else{
} catch (e) {
// Label translation
if (!labelEle) {
if (labelEle) {
if (listContains) {
trLabels = [];
trLabelsHtml = "";
/* try{
for(var j=0;j,';
trLabelsHtml = trLabelsHtml+'
