ron_horne
clone a column
Hi All,
I want to clone a column in the data table (make a new identical column in all but it’s name). Is there a more sleek (and robust) way of doing this or do I need to extract the values and all properties and assign them to the new column as such:
dt3 = Open( "$SAMPLE_DATA/Cars.jmp" );
// add a column property
dt3:Make << Set Property(
          "Value Colors",
          {"Acura" = -13977687, "Audi" = -3780931, "BMW" = -4222943, "Buick" = -
          13596966, "Cadillac" = -2211217, "Chevrolet" = -10562780, "Chrysler" = -
          13156647, "Daihatsu" = -2078390, "Dodge" = -13182413, "Eagle" = -9549600,
          "Ford" = -2334147, "Geo" = -13772446, "Honda" = -9282864, "Hyundai" = -
          6995852, "Infiniti" = -1524612, "Isuzu" = -9458080, "Jeep" = -14452073,
          "Lexus" = -6391856, "Lincoln" = -2745505, "Mazda" = -10199751, "Mercedes" =
          -7150697, "Mercury" = -10513726, "Mitsubishi" = -8381519, "Nissan" = -
          3502441, "Oldsmobile" = -3615440, "Peugeot" = -13925307, "Plymouth" = -
          11502354, "Pontiac" = -7449196, "Renault" = -9229791, "Saab" = -4074344,
          "Saturn" = -13050224, "Subaru" = -12565885, "Suzuki" = -2068529, "Toyota" =
          -4494272, "Volkswagen" = -11824110, "Volvo" = -8734293, "Yugo" = -13849421}
     ) << color cell by value;
// clone the column
clone_column = dt3:Make << Get script;
clone_column;
3 ACCEPTED SOLUTIONS
Re: clone a column
Here is a completed example of one way to prepend the data table pointer:
Eval(Parse("(dtxxx<<"||char(dt3:Make << Get script)||") << set name(\!"Clone\!");"));
ron_horne
Re: clone a column
thanks Dave@Pega-Analytics txnelson​,
this is what i was looking for. i didn't expect duplicating a column to be so cumbersome.
the following is my final script:
dt3 = Open( "$SAMPLE_DATA/Cars.jmp" , private);
// clone into the same table
Eval(Parse("(dt3<<"||char(dt3:Make << Get script)||") << set name(\!"Clone\!");"));
// proof that the column was cloned - check log
dt3:Clone << get script;
close (dt3, no save);
best,
ron
msharp
Re: clone a column
I'm really not sure what value there is in keeping column properties like value colors in a private table.  If the data is all you care about (typically true for private tables), the simpler method below could be used.:
dt3 << New Column("Make Clone", Formula(dt3:Make))
12 REPLIES 12
ms
Super User (Alumni) ms
Re: clone a column
That looks very sleek to me. Have you experienced any problems with robustness?
If you do not want to waste memory on a variable it can be simplified into a oneliner:
Eval(dt3:Make << Get script) << set name("Clone");
For cloning multiple columns , I would consider making a subset of these, rename the columns and update with the original data table.
ron_horne
Re: clone a column
Thanks MS​,
i am surprised there is no jsl command for duplicating an existing column. in addition, if dt3 is not the active table it creates the new column in an other table.
David_Burnham
Re: clone a column
You can make it more robust by editing the script variable prior to evaluation i.e. prepend "dt << " to the expression.
-Dave
Re: clone a column
ron_horne
Re: clone a column
best,
ron
msharp
Re: clone a column
ron_horne
Re: clone a column
Thanks MS​,
It is true that colors are not very useful in a private table.
the thing is that I am writing an algorithm based on a heuristic process. this means that I need to have a script that would do what i would if i had to "read" the data lines one by one my self and interpret it (here is where i need the colors). on the other hand the script needs to be fast when running so i need to bounce back and fourth between tables I see and fast running ones (private). this transition between visual and private tables introduces robustness challenges while scripting across a few open tables.
ron
ron_horne
Re: clone a column
the robustness issue came when using private tables since the clone was sent to another table which was not private.
owg
owg
Re: clone a column
Hi MS, Would you mind explaining how this command clones the selected column in a dt? Eval(dt3:Make << Get script) << set name("Clone"); I realize this is not normally the kind of question asked here and it was 5 years ago but this is the most opaque command I have seen in any programming language I have used. I works great however!
