  • See how to import and prepare Excel data. Jan. 30, 2-3 pm US ET. Register.
learning_JSL
need to extract slope and intercept from parameter estimates table in a linear least squares model fit and save to a file
My code is not working and I'm having trouble identifying why.  Any help would be most appreciated - thanks!
dt = Open("C:\Users\trcampbell\Desktop\MASTER ECOLI\2025\2024.xlsx");
obj = Fit model(
Y( :LOGECOLI ),
Effects( :LOGTURB),
Emphasis( "Effect Leverage" ),
Run(:LOGECOLI )) ;
// Extract slope and intercept
reportObj = obj << Report;
paramTable = reportObj( "Parameter Estimates" );
// Extract values from Parameter Estimates table
intercept = paramTable[estimate(1)];  //1st column
slope = paramTable[estimate(2)];  //2nd column
// Create a new data table to store the results
results = New Table( "Fit Results",
    Add Column( "Parameter", Character, Set Values( {"Slope", "Intercept"} ) ),
    Add Column( "Value", Numeric, Set Values( {slope, intercept} ) )
// Save the results to an Excel spreadsheet
results << Export( "C:\\Users\\trcampbell\\Desktop\\MASTER ECOLI\\2025\\validation results\\test xxx.xlsx");
Re: need to extract slope and intercept from parameter estimates table in a linear least squares model fit and save to a file
Hi @learning_JSL ,
I've altered your script to take advantage of the 'make into data table' function to bring the details over, but I've also added where your challenges with the script were by changing the paramtable to target the specific estimates section of the table - if you want to find how to do this it's best to right click>properties and highlight the estimates section to find the path to the object.
I've used the sample data folder here just to test that it works.
dt=Open("$SAMPLE_DATA/Tablet Production.jmp");
obj = Fit model(
Y( :Dissolution ),
Effects( :Mill Time),
Run(:Dissolution )) ;
paramTable = ReportObj["Response Dissolution","Whole Model","Parameter Estimates",TableBox(1)]; //Change the report to target the table that needs saving
/*In the old method you had, you could instead make param table this to target the specific estimate column, just change the Y name:
paramTable = reportObj["Response Dissolution","Whole Model","Parameter Estimates",NumberColBox("Estimate")];*/
/*intercept = paramTable[1];  //1st column - grab the first item [corrected from what you had]
slope = paramTable[2];  //2nd column - grab the second item*/
dtnew=paramTable<<make into data table;
// Save the results to an Excel spreadsheet as you have
dtnew << Export( "C:\\Users\\trcampbell\\Desktop\\MASTER ECOLI\\2025\\validation results\\test xxx.xlsx");
Byron_JMP
The same code works for me
obj = Fit model(Y( :Dissolution ),Effects( :Mill Time),Personality( "Standard Least Squares" ),Emphasis( "Effect Leverage" ),Run(:Dissolution )) ;
rpt=obj<<report;
rpt["Response Dissolution", "Whole Model", "Parameter Estimates", Table Box( 1 )] << Make Into Data Table;
It could be that you're using an older version of JMP?
maybe try using a different platform
Fit y by X
rpt = New Window( "Tablet Production - Fit Y by X of Dissolution by Mill Time",
	Data Table( "Tablet Production.jmp" ) <<
	Bivariate(Y( :Dissolution ),X( :Mill Time ),
	Fit Line( {Line Color( {230, 159, 0} )} )
rpt["Bivariate Fit of Dissolution By Mill Time", "Linear Fit", "Parameter Estimates",
or this one
Fit Curve
rpt = New Window( "Tablet Production - Fit Curve of Dissolution by Mill Time",
	Fit Curve( Y( :Dissolution ), X( :Mill Time ), Fit Linear ));
rpt["Fit Curve", "Linear", "Parameter Estimates", Table Box( 1 )] <<
6 REPLIES 6
Hi @learning_JSL ,
obj = Fit model(
Y( :Dissolution ),
learning_JSL
Thanks Ben.
I am getting this error:
Byron_JMP
rpt=obj<<report;
Fit y by X
or this one
Fit Curve
learning_JSL
Thanks so much!
One small change I would consider doing when looking for the reference, is to drop the column name from the first outline box reference ("Dissolution" in this case) as it makes it more robust. You could either ignore that outline box or you could use wildcard "?" in place of the column
dt = Open("$SAMPLE_DATA/Drug.jmp");
fm = dt << Fit Model(
	Y(:y),
	Effects(:Drug, :x),
	Personality(Standard Least Squares),
	Run Model()
rep = Report(fm);
// tb_param_estimates1 = rep["Whole Model", "Parameter Estimates", TableBox(1)];
tb_param_estimates2 = rep["Response ?", "Whole Model", "Parameter Estimates", TableBox(1)];
Usually I also add those outlineboxes there, but its a preference
rep[OutlineBox("Response ?"), OutlineBox("Whole Model"), OutlineBox("Parameter Estimates"), TableBox(1)];
learning_JSL
Thank you Jarmo!!  Most appreciated!
