Mickyboy
n rows doesn't mean n
Hi All,
I got some descriptive's from JMP, included in the output was: N Rows, l thought that is handy l would need that later on, unfortunately this is a count of the actually rows and not n, as l have some missing data, is there a simple line of code in JMP that l can get the actual n and not count the missing data, similar to na.rm = TRUE, by groups, the code i used is as follows:
dt3 << Summary(
	Group( :Scale Area, :Process Step, :Subtype, Quality Attribute ),
	Mean( :Data ),
	Std Dev( :Data ),
	Std Err(:Data),
	Freq( "None" ),
	Weight( "None" ),
	Output Table( "Descriptives" ),
	Link to original data table(0)
dt4 = Data Table( "Descriptives" ) << Split(
			Split By( :Scale Area ),
			Split( :"Mean(Data)"n, :"Std Dev(Data)"n, :N Rows, :"Std Err(Data)"n  ),
			Group( :Process Step, :Subtype, :Quality Attribute ),
			Remaining Columns( Drop All ),
			Output Table( "Mean Ratio"),
			Sort by Column Property
Any suggestion would be appreciated.
Thanks,
Mick.
Re: n rows doesn't mean n
Have you tried checking out the different options Summary platforms offers you? Using JMP > Summarize Your Data > Explanation of Summary Statistics
Mickyboy
Sorry jthi,
it was late and l was tired and frustrated, l was actually looking for "N(data)"n, that does the job nicely, thanks very much for your reply.
Regards,
Mick
Mickyboy
Sorry jthi,
Regards,
Mick
