DownloadSemiconductor Toolkit: Tools to create wafer maps, add wafer geometry to graphics, explore die defects & compare wafers.
Discovery Summit 2026: Early User Edition - September 23-24.Register. It's free.
Use JMP Clinical with CDISC-compliant data. Review studies, ID safety and efficacy signals & communicate findings with interactive graphics. Register to see how. Aug. 27, 2 pm US ET.
When working interactively you might do this with the profiler. Create a column with the formula you want to maximize, then open the profiler, set desirability functions, and then maximize desirability.
Table with formula:
In profiler of y, show desirability functions:
Control+click (in windows) on the desirability function, set it to maximize and give it a range to search:
Adjust the axis settings and then run maximize desirability:
Which does identify the value of X that maximizes Y:
