norman21
World map projection
Does anyone know the default type of world map projection used in JMP? Ideally with a reference that can be cited.
It looks like a Mollweide projection, but it would be great to have some factual information to support this.
Thanks,
Norman.
JMP® Pro 17.01.0 running on Windows 10
jules
Re: World map projection
Hi @norman21,
In JMP the regional scale uses an Albers equal area projection, and the world scale uses a Kavrayskiy VII compromise projection. You can read a little more about these image maps in the jmp documentation.
I hope this helps!
@jules
jules
Hi @norman21,
I hope this helps!
@jules
norman21
Thanks Julian, this is exactly the information needed (and... how interesting!)
However, I see that the JMP documentation states "JMP uses a couple of projections (Albers Equal Area Conic and Kavrayskiy VII) for its maps.", which is a little vague. Is there a way to amend the wording so that it says what you have written?
Norman.
jules
Absolutely, Norman! I had the same thought once I read what was written there, and I'll make sure our documentation team is aware of this so they can get it updated.
@jules
