statslearner
mathematical expression for the linear discriminant model
EXTERNAL
Hello JMP Team,
Kindly indicate how to get the mathematical expression for the linear model when executing linear discriminant analysis. I wish to see the constant and the predictor variables coefficients.
I am using sample data Iris.jmp
Thanks.
Regards
Chandra
Re: mathematical expression for the linear discriminant model
Usually the platforms which perform predictions do have option somewhere to save the formula to table. These can be found from the red triangle menu and you can make it a bit easier by utilizing the filtering capability
Multivariate Methods > Discriminant Analysis > Discriminant Analysis Options
