johanna_younous
losses of information in a graph box saved in journal
My english may not be clear I apologise in advance if it's the case.
I try to create a graph in a graph box that I want to save in a journal.
To create lines in my graph, I have to put coordintates in a variable because this may be changing depending on some parameters in my data.
Everything is running fine until I save the journal. But when I re-open this journal from an other jmp session or even if I just run "clear globals"  I loose everything. In fact , in the journal script, my variables keep their name and if I erase what is assign to my variable then the script of the journal will be bugging ( as it does not recognize  anymore my variable).
I tried to put the code in an expression, to put it in a function, to use the "eval" or "eval(parse()" command and nothing id working so far which is driving me crazy.
Does anyone had the problem or have a clue to fix it?
Here is a code that re-create the problem
path ="C:\";
Var1=[10 30 90];
Var2=[88 22 44] ;
obj=New Window( "Example", Graph Box( Line( Var1, Var2 ) ) );
obj<<journal;
jrn= Current Journal();
jrn<<Save Journal(path||"jrn_test.jrn");
jrn<< close window();
obj<<close window();
clear globals();
path ="C:\";
open(path||"jrn_test.jrn");
Thank you very much in advance !
ps : I'm using JMP14.1.0 (64bits)
Re: losses of information in a graph box saved in journal
I'm using JMP16.2 so hopefully the issues are same. I get following error message Name Unresolved: Var1 in access or evaluation of 'Var1' , Var1/*###*/ which tells me that when the journal is re-opened the variables are no longer defined. To avoid this I would try one of the methods found fromInsert one expression into another using Eval Insert, Eval Expr, Parse, and Substitute . These will allow you to evaluate the values to the graph box instead of just leaving it as Var1 and Var2. Below is an example using Eval(EvalExpr()).
path = "$TEMP\";
Var1 = [10 30 90];
Var2 = [88 22 44];
Eval(
	EvalExpr(
		obj = New Window("Example", Graph Box(Line(Expr(Var1), Expr(Var2))));
obj << journal;
jrn = Current Journal();
jrn << Save Journal(path || "jrn_test.jrn");
jrn << close window();
obj << close window();
wait(1);
Open(path || "jrn_test.jrn");
Non-evaluated:
Evaluated:
path = "$TEMP\";
Var1 = [10 30 90];
Var2 = [88 22 44];
Eval(
	EvalExpr(
obj << journal;
wait(1);
Non-evaluated:
Evaluated:
johanna_younous
Thx !!!
It seems to work perfectly!
