Level XIII
linked data table: how to cut the "link"?
Summary Tables and Subsets have an option to "link" the new table to the original data table.
"Data views" have such a link enabled by default.
Cool:
Row Selections and changes to the values are automatically linked between the tables.
But sometimes one needs to remove such a link
- to add additional rows to the main table
- to rename columns of the linked table
Links cannot be saved, so, one can save the tables, close both tables and open the "linked" table again - without the link.
Is there a faster way?
a right click on hogi_1-1667417754319.png doesn't seem to be the right way ...
Re: linked data table: how to cut the "link"?
I'm not sure if there is any way to remove the "linked subset" property.
You could first create subset of the linked table and then you can close the linked table.
Level XIII
The only way that I know of to break the link, is to save the table, close the table, then open the table, and the link will no longer be in place.
Level XIII
Sorry Holger, don´t know a better solution either. :(
Level XIII
