KK3000
k-factors for tolerance intervals
Hi all,
the k-factor JMP uses for the upper/lower tolerance intervals are different from the ones we use in our company. Does anyone know where the k-factors of JMP are taken from? And can I get the whole k-factor tables?
I am supposed to change the tables which our company uses to the JMP tables.
Thanks
Katharina
10 REPLIES 10
KK3000
Re: k-factors for tolerance intervals
Hi, we use tables from statistic books. Both for one-sided and two-sided intervals. I thought that JMP does that equally. I wasn't aware that JMP calculates the k factors. I will have a look at all the formulas and at the reference documents. I still hope I can find a table, at least for the typical confidence intervals and populations we need.
