See how to use to use Text Explorer to glean valuable information from text data at April 25 webinar.
isolating the smallest date difference
jsolo01
i have a large dataset that has a static date on a subject (date of chest CT scan) and i need to find the smallest date difference and keep that row (delete the others).  jmp 16.2.0
Example below - i want to keep rows 2 and 4 (the smallest day difference for subject 1 and 2).
subj ID.    CT date.      lung function date.      day difference
1               8/30/18            1/29/18                          -213
1               8/30/18            8/31/18                              1
1               8/30/18            3/4/19                              186
2              12/19/17           11/13/18                          329
2              12/19/17            9/3/19                             623
2              12/19/17           10/4/21                            1385
WebDesignesCrow
Re: isolating the smallest date difference
Hi @jsolo01 ,
How about adding a new formula column "Col Rank" to rank the day difference according to subj ID.?
Then, you can select row "Col Rank" not equal to 0 & delete the rows.
For;
subj ID 1, the min day difference is the 2nd row.
subj ID 2, the min day difference is the 4th row
1) Create new formula column: Col Rank
2) Go to Rows > Row Selection > Select Where
3) Define the condition: Col Ran does not equal 1 > click "Add Condition"
4) Right click the selected rows > Delete Rows
5) Final result as below
Hope it helps.
If it's a repetitive analysis, you can automate the steps through workflow or JSL
Here is my take on a simple way to get what you are asking for;  Just a simple script
dt << select where( :day difference == Col Min( :day difference, :subject ID ) );
dt << subset( selected columns( 0 ), selected rows( 1 ) );
Just to extend a little on @WebDesignesCrow interactive solution:
If you don't already have the difference column, you can create it interactively (select both of your dates, right click on the column header and find Difference (reverse order). This will create a new column where the differences are in seconds. If you want to see them in yours/days you can double click on the created column and modify it as needed (such as add division by In Days(1)) but seconds work for this case
Then right click on this new column's header and make absolute value column out of it
After you have that column, right click on the subjectid column and make it grouping column
next you can right click on the date difference column and create rank formula (note the grouping)
from the final column, right click on one of the "ones", select matching cells
From here you can either create subset using selected rows
OR right click on the row list, invert selection and after inversion delete rows
Then if you need to repeat this you can either make a workflow or capture the script from enhanced log
Below is script created by Workflow builder. Only thing it is missing is opening the table as I don't have the table saved (and some column names are incorrect for the same reason) so I added table creation script (workflow is also attached).
View more...
//Custom Action - Create table 'Untitled 2'
dt = New Table("Untitled 2",
	Add Rows(6),
	Compress File When Saved(1),
	New Column("subj", Numeric, "Continuous", Format("Best", 12), Set Values([1, 1, 1, 2, 2, 2])),
	New Column("day1",
		Numeric,
		"Continuous",
		Format("m/d/y", 12),
		Input Format("m/d/y"),
		Set Values([3618432000, 3618432000, 3618432000, 3596486400, 3596486400, 3596486400])
	New Column("day2",
		Numeric,
		"Continuous",
		Set Values([3600028800, 3618518400, 3634502400, 3624912000, 3650313600, 3716150400])
//New formula column: day2-day1
Data Table("Untitled 2") << New Formula Column(
	Operation(Category("Combine"), "Difference (reverse order)"),
	Columns(:day1, :day2)
//New formula column: Abs[day2-day1]
	Operation(Category("Transform"), "Absolute Value"),
	Columns(:"day2-day1"n)
//New formula column: Rank[Abs[day2-day1]][subj]
	Operation(Category("Distributional"), "Rank"),
	Columns(:"Abs[day2-day1]"n),
	Group By(:subj)
//Select matching cells
Data Table("Untitled 2") << Select Where(:"Rank[Abs[day2-day1]][subj]"n == 1);
//Subset data table
Data Table("Untitled 2") << Select Where(:"Rank[Abs[day2-day1]][subj]"n == 1) <<
Subset(Selected Rows(1), Selected columns only(0));
