tonyuow
invert y-axis
is it possible to invert the y-axis in a graph?
thanks
pmroz
invert y-axis
Yes.  Double click on the Y axis and switch the max and min values.
tonyuow
invert y-axis
but if I create graphs using the "By" field and I get, say, 10 sub-graphs, that means I have to do this on every 10 graphs, which is not time efficient. Any way to do this when creating the graph?
thanks
ms
Super User (Alumni) ms
invert y-axis
Good point. However, you can add the reversed limits in the Axis property to force all the sub-plots to have the same y-axis settings. First make a rough graph without "By" to get an idea of appropriate max and min etc and then enter those in the Axis property of the column.
