import bank statements data from pdf
Is JMP able to import credit card statements into excel/JMP table? Or does it only work from text files?
If not, could I convert pdf into text, then could it recognize the rows I am trying to import into JMP?
THANKS!!!
Kara
Re: import bank statements data from pdf
Yes, JMP can open pdf files.
 Go to:     Help=>JMP Online Help=>PDF
The PDF Import Wizard enables you to preview a PDF file, adjust the import settings, and view the results in the data table preview before you import the data. JMP attempts to auto-detect the data structure in the PDF file, or you can customize the structure.
Craige_Hales
...and it gets better: you probably have a directory of pdfs of statements collected for several years. If the bank has not changed the format, you can use the script JMP saved to the data table to import and stack them
Craige
SawyerTanner
Absolutely! Converting to text works, JMP handles it well.
View more...
Importing data from PDFs can be a pain—I've faced similar challenges managing casino transaction histories. That's why it's helpful to know about options like https://zarubezhnye-kazino.com/et/hasartmangu-keeld/hasartmangu-keelu-tuhistamine/ which explain how to lift gaming bans or restrictions when needed. Whether organizing finances or your gameplay, good data management is a win.
