Françoise
image in a label
I have a database JMP. There are 2 columns "expression" with image (JPG) inside and labelled.
I thought that JMP will show the 2 images in the label of a point but there is only one.
is it possible to have more than 1 image in a label?
best regards
3 ACCEPTED SOLUTIONS
Re: image in a label
I usually either create new column which combines them into single image and use that or hover labels. Below is hover label example (it does require some scripting)
dt = Open("$SAMPLE_DATA/Big Class Families.jmp");
gb = dt << Graph Builder(
	Size(534, 456),
	Show Control Panel(0),
	Variables(X(:height), Y(:weight)),
	Elements(Points(X, Y, Legend(6)))
frame = (gb << report)[FrameBox(1)];
frame << Set Graphlet(
	Picture(
		hlb = H List Box(Picture Box(:picture[local:_firstRow]), Picture Box(:pet[local:_firstRow]))
Nowadays there might be some easier options but these are the ones I'm used to
I am not aware of a way to do this in JMP directly.  However, you can create a new column that has both images joined together and then use that as your label column.
Here is a simple example:
dt = Open( "$SAMPLE_DATA/Big Class Families.jmp" );
dt << New Column( "together", expression );
For( i = 1, i <= N Rows( dt ), i++,
	hlb = H List Box( dt:picture[i], dt:pet[i] );
	dt:together[i] = hlb << get picture;
dt:picture << label( 0 );
dt:pet << label( 0 );
dt:together << label( 1 );
Graph Builder(
	Size( 528, 456 ),
	Variables( X( :weight ), Y( :height ) ),
	Elements( Points( X, Y, Legend( 6 ) ), Smoother( X, Y, Legend( 7 ) ) )
Level XIII
If you have Jmp16 or above, you can use Hover Label / Label Viewer to enable Graph builder to show more than a single picture as label:
	Size(534, 456),
	Picture(
Graph Builder(
	Size( 528, 456 ),
Level XIII
Françoise
thanks for all answers.
I use the solution of Jim. Its OK.
Best regards
