cchueng
Open all jsl files in a folder, find and replace text, save and close files
I want to write a script to open many jsl files in a folder. In each jsl file, I need to find a text and replace it with another text. Save each file and close it before going onto the next file in the folder. I tried to use "substitute" but did not work. Appreciate all the help!
//folder contains 224 jsl scripts
folderID = "T:\JMP_SCRIPTS\Openfiles n update\test\";
Files = Files In Directory(FolderID);
For(i = 1, i <= N Items(Files), i++,
	FileID = Files[i];
//Open jsl file
	openFile = Open(folderID || FileID);
	subdt = Substitute(openFile, "99@wefghynKm0r3", "hihi");
	openFile << Save(folderID || FileID);
	Close(openFile, No Save);
);// End FOR loop
Re: Open all jsl files in a folder, find and replace text, save and close files
Look into using
     Load Text File()
and
     Save Text File()
rather than using Open().
Load Text File() will bring the complete file into a single literal string variable and you will then be able to use Substitute() for the string and then save it back using the Save Text File.
Look into using
     Load Text File()
and
     Save Text File()
cchueng
Facinating, thanks! It works for me!
