Isabel26
if any easy script for wild card. want to select columns by using wild card
OK, is there an easy general way to use wild card in jmp scripting? I need to list all columns that start with 'Row' (like Row1 Row2 Row3...) in COLUMN COMBINE commend. Thanks.
vince_faller
Re: if any easy script for wild card. want to select columns by using wild card
 Don't know.  This works for me.
Names default to here(1);
dt = New Table( "Untitled 231",
	Add Rows( 1 ),
	New Column( "ID", Set Values( [1] )),
	New Column( "Row1", character, Set Values( {"a"} )),
	New Column( "Row2", character, Set Values( {"b"} )),
	New Column( "Row3", character, Set Values( {"c"} )),
	New Column( "Row4", character, Set Values( {"d"} )),
	New Column( "Row5", character, Set Values( {"e"} )),
partial_column = function({searchtxt, dt=currentdatatable()},
	{default local},
	allCols = dt << GetColumnNames("String");
	filtered_list = {};
	for(i=1, i<=nitems(allCols), i++,
		if(isstring(regex(allCols[i], searchtxt)),
			insert into(filtered_list, allCols[i]);
	return(filtered_list);
dt << Combine Columns(
	Columns(partial_column("Row.")),
	Column Name( "ALL" ),
	Delimiter( " " )
Vince Faller - Predictum
6 REPLIES 6
vince_faller
You can wildcard, but it will only get the first.
dt = open("$SAMPLE_DATA\Big Class.jmp");
Column(dt, "?eight"); //Column( "height" )
it's an easy enough loop though
	{default local},
	filtered_list = {};
partial_column(".eight"); // {"height", "weight"}
Isabel26
I want to combine Row1 to Row5 (i want it automate since i may have Row100 in real dataset), and I cannot just wild card like this? If I add the loop, not sure where to put it.
EG Dataset;
ID  Row1 Row2 Row3 Row4 Row5 ALL
1    a        b        c         d        e        a b c d e
My code:
Data Table( "Transpose of stack sort") <<
Combine Columns(
partial_column("Row?"),
Delimiter( " " )
vince_faller
Two things, you need to put Columns() around your columns, and wildcards for regex is "."
So you probably need to do something like this
	Combine Columns(
	Delimiter( " " )
Isabel26
This sounds the solution, but I got this error when I run it.
vince_faller
	Add Rows( 1 ),
	{default local},
	filtered_list = {};
	Delimiter( " " )
You might be able to use JMP Patterns for this task.
