Technician
Variability Chart Platform Factor Re-Insert Positions (Not Swapping)
Hello JMP Community,
I understand dragging between any two factors swaps the location pairs in the Variability Chart platform. Is there a way to drag to specifically re-insert the factors instead? For example, can I drag "Layout" between "Horizontal" and "Wafer ID" in the attached screenshot instead of performing multiple drags to have the intended result? I am aware I can do this reordering with "Relaunch Analysis".
I am asking because my real data has more than 10 factors. It would be much easier to reorder directly on the platform. Let me know if this should be a feature request, with which perhaps using Ctrl+Drag or Alt+Drag might be a helpful combination.
Thanks,
Technician
0 REPLIES 0
