wcheon3
Community Trekker
how to write JSL script to report out 20 plots/graphs in one combined report and close all the 20 individual plots?
I wrote a script which after running would open 20 windows for each plot in the script besides the data tables.  How to write in the JSL script to report out 20 plots/graphs in one combined report and showing all the original 20 individual plots?  Tried the following script but did not return with anything.
rptPIC = plotPIC << report;
w1 = New Window( "Trend Charts",
Text Box( " run date/time: " || ::Date || " MST" ),
IWSWS = Outline Box( "Trending",
Text Box( " " ),
H List Box( rptPIC ),
Text Box( " " ),
Text Box( " " ),
H List Box( rptLIC ),
Text Box( " " ),
Text Box( " " )
msharp
Re: how to write JSL script to report out 20 plots/graphs in one combined report and close all the 20 individual plots?
It's going to be best if you put all your reports directly into one window from the beginning.  Creating a report and then moving it is difficult.  Use the 'nw = New Window("container"); nw << Append(report);' format.  For example:
//Get Example Data
dt = open("$Sample_Data\Big Class.jmp");
//Create Distribution report
dist = dt << Distribution( Continuous Distribution( Column( :height ) ) );
//deson't work b/c the display box is in another window
nw = new window("Example", dist);
nw2 = new window("Example2");
//Create the window directly in the container we want it to be in
nw2 << Append(dist = dt << Distribution( Continuous Distribution( Column( :height ) ) ););
msharp
//Get Example Data
vince_faller
Adding on msharps reply.  If you do want to create a variable to put it into the window, you can always just wrap your platform in Expr()
//Create Distribution Expr
dist = Expr(dt << Distribution( Continuous Distribution( Column( :height ) ) ));
//works now
Vince Faller - Predictum
wu
wu
Community Trekker
What is the reason that without add"Expr",
the dist object does not appear in the new window with script below :
vince_faller
Just like previous reply, because it's already in another window.
wu
wu
Community Trekker
Thanks.
