wcheon3
how to write JSL script for basic equations, and then make an overlay plot out of it?
I have several points defined in an JSL script and running that would generate a table and also overlay plots for each point.
Say I have point1, point2, point3
I want to define that
RATIO1 = point1*100/(point1+point2+point3)
RATIO2 = point2*100/(point1+point2+point3)
RATIO3 = point3*100/(point1+point2+point3)
Then plot overlay of RATIO1, RATIO2, RATIO3 versus timestamp.
I tried to use Assign(RATIO1, point1*100/(point1+point2+point3)) but did not work.  I also tried the operators such as
Assign(RATIO1, Multiply(100, Divide(point1, Add(point1, point2, point3))));
but it still didn't work for the overlay plot as the error said it cannot find the role of defined Y.  Can you please let me know if there's anything wrong with the script?  I also tried :"RATIO1" or name("RATIO1") or putting the exact equation above when plotting Y below...all didn't work.
DT is the database:
DT << Overlay Plot(
X( :Timestamp ),
Y(
:RATIO1
:RATIO2
:RATIO3
ian_jmp
Level X
Re: how to write JSL script for basic equations, and then make an overlay plot out of it?
Is this close to what you require? Copy and paste this code into an editor window, then 'Edit > Run Script'. Then look at the formulas in the 'RATIOn' columns.
NamesDefaultToHere(1);
// Example table
dt = New Table( "Date and Times in 2014",
Add Rows( 100 ),
New Column( "Date",
Numeric,
"Continuous",
Format( "ddMonyyyy h:m:s", 22, 0 ),
Input Format( "ddMonyyyy h:m:s", 0 ),
Formula(
Random Integer( Date DMY( 1, 1, 2014 ), Date DMY( 31, 12, 2014 ) )
New Column( "p1", Numeric, Continuous, Formula( Random Uniform() )),
New Column( "p2", Numeric, Continuous, Formula( Random Uniform() )),
New Column( "p3", Numeric, Continuous, Formula( Random Uniform() )),
New Column( "RATIO1", Numeric, Continuous, Formula( :p1*100/(:p1 + :p2 + :p3 ))),
New Column( "RATIO2", Numeric, Continuous, Formula( :p2*100/(:p1 + :p2 + :p3 ))),
New Column( "RATIO3", Numeric, Continuous, Formula( :p3*100/(:p1 + :p2 + :p3 ))),
// Shoow time series in Graph Builder
dt << Graph Builder(
Show Control Panel( 0 ),
Variables( X( :Date ), Y( :RATIO1 ), Y( :RATIO2 ), Y( :RATIO3 ) ),
Elements( Position( 1, 1 ), Line( X, Y, Legend( 11 ) ) ),
Elements( Position( 1, 2 ), Line( X, Y, Legend( 12 ) ) ),
Elements( Position( 1, 3 ), Line( X, Y, Legend( 13 ) ) )
wcheon3
Here's my code with extracting the points, and currently it's plotted with each point but I want to do some arithmetic formulas using those points and plot them as overlay.  How to correctly define the formula/equation in the script and then how to plot in Y.  You can see the previous effort I tried in the first message.
DT = Open Database("DRIVER=S Server;SERVER=SP.trend.com,0000",
"DECLARE @StartDateTime datetime = DATEADD(dy, -1, GETDATE())
DECLARE @EndDateTime   datetime = GETDATE()
EXEC ListData @Criteria='
<SPORTAL>
  <Data Name=\!"PointData\!" Format=\!"Wide\!" Interval=\!"120m\!">
    <Columns>
      <Column Name=\!"Timestamp\!" />
      <Column Name=\!"Project\!" />
      <Column Name=\!"Point\!" />
      <Column Name=\!"DataValue\!" />
    </Columns>
    <Where>
      <Column Name=\!"Point\!" Project=\!"XX\!" Value=\!"XX_POINTA\!" />
      <Column Name=\!"Point\!" Project=\!"XX\!" Value=\!"XX_POINTB\!" />
      <Column Name=\!"Point\!" Project=\!"XX\!" Value=\!"XX_POINTC\!" />
      <Column Name=\!"Point\!" Project=\!"XX\!" Value=\!"XX_POINTD\!" />
    </Where>
  </Data>
</SPORTAL>'
, @StartDateTime=@StartDateTime
, @EndDateTime=@EndDateTime"
plotRATIOS = DT << Overlay Plot(
X( :Timestamp ),
Y(
  :XX_POINTA,
  :XX_POINTB,
  :XX_POINTC,
  :XX_POINTD
    Sort X( 0 ),
Connect Thru Missing( 1 ),
Connect Points( 1 ),
Automatic Recalc( 0 ),
  Dispatch( {}, "102", ScaleBox, {Format( "Best", 10 )} ),
  Dispatch(
   "101",
   ScaleBox,
   {Format( "m/d/y", 10 ), Rotated Labels( "Vertical" )}
  Dispatch( {}, "Overlay Plot Graph", FrameBox, {Frame Size( 571, 450 )} )
