Batista
how to use join, update and concatenate
Hi need more information when to use this tools:  join, update and concatenate.
Witch one shoul i use to combine to two table that have same column names  but different ID patients? How to add all the patients and make one table?
Another question is how to update a table with new data?
markschahl
Re: how to use join, update and concatenate
Batista:
Help > Tutorials has two Join and one Stack tutorials.
There are a few videos on JMP's YouTube Channel:
This is all covered in the Documentation...….Using JMP
Help==>Books==>Using JMP
markschahl
Batista:
Jeff_Perkinson
Tables->Concatenate is what you need when you have two table with the same columns that you want in one table.
It depends on what you mean about updating. If you get another table with the same columns but new rows you can use Tables->Concatenate again. There's an option to Append to the first table. That will update the main table instead of creating a new table.
-Jeff
