fredwcf
how to use JSL to change the column data type &format
I  want to  the column data type (charactor ---numeric) and format (best----engineering si)  using JSL.I tried some scripts such as below ,but no works. Please help and any sultion will be appreciated .
dt <<Column( "Freq(Hz)"<< data type( numeric ) << Format( "Engineering SI" )
Re: how to use JSL to change the column data type &format
If you are using JMP 16, try making the change interactively and then looking in the enhanced log (View > Log on Windows).  Many interactive actions will give sample scripts for the operations that you perform.  I tried this with the Blenders.jsl sample data and it gave this:
// Change column info: Time Cycles
Data Table( "Blenders" ):Time Cycles << Data Type(
	Numeric,
	Format( "Engineering SI", 9 )
) << Set Field Width( 12 );
 If you have a dt table variable, you can use that in place of Data Table("Blenders").
	Numeric,
fredwcf
I am using JMP 16, thank you for telling me the  Log window function .it's very helpful .
