Cheli
how to sumerize the number column with of identical value per row in jmp
Hi
who know how to summarize the number column with of identical value per row in jmp?
for example:
MovieYearDomestic $######SUM
Ocean's Eleven2001$ 183.40$ 444.30$ 183.402
Airport1970$ 100.50$ 100.50$ 100.503
Armageddon1998$ 201.60$ 554.60$ 271.600
Batman1989$ 251.20$ 413.00$ 413.002
Batman & Robin1997$ 107.30$ 237.30$ 107.302
Batman Forever1995$ 335.00$ 335.00$ 335.003
thanks
Cheli
Re: how to sumerize the number column with of identical value per row in jmp
Assuming you are running an interactive JMP session, simply double click on the column header of the column in question, and change the name to whatever name it should have.
Cheli
thanks. but I didn't explain my question well.
I need to summarize the number of columns with identical occurrence for each row.
I need to create columne same as "SUM" at my example
If you have only three columns you could use Choose with checking of how many unique values there are. I'm using (N Items(Associative Array(Eval List({:A,:B,:C})) << get keys)) for that here
dt = New Table("Untitled",
	Add Rows(6),
	Compress File When Saved(1),
	New Column("Movie", Character, "Nominal", Set Values({"Ocean's Eleven", "Airport", "Armageddon", "Batman", "Batman & Robin", "Batman Forever"})),
	New Column("Year", Numeric, "Continuous", Format("Best", 12), Set Values([2001, 1970, 1998, 1989, 1997, 1995])),
	New Column("A", Numeric, "Continuous", Set Values([183.4, 100.5, 201.6, 251.2, 107.3, 335])),
	New Column("B", Numeric, "Continuous", Set Values([444.3, 100.5, 554.6, 413, 237.3, 335])),
	New Column("C", Numeric, "Continuous", Set Values([183.4, 100.5, 271.6, 413, 107.3, 335])),
	New Column("SUM", Numeric, "Continuous", Format("Best", 12), Set Values([2, 3, 0, 2, 2, 3]))
dt << New Column("SUM2", Numeric, Continuous, Formula(
	Choose(N Items(Associative Array(Eval List({:A,:B,:C})) << get keys),
		3,
		2,
		0
Edit:
As @txnelson said, Associative Array doesn't really work with non integer numeric values unless you transform the values somehow (you could try converting them to characters first or multiply). With three columns it will be short to write a formula with comparisons (like Jim did). Also instead of Associative Array you could use Design
	val = Max(V Sum(Design(Eval List({:A,:B,:C}))));
	If(val > 1,
		val
		0
An issue arises with @jthi code when the comparison values in the Associative Array are not integers.  The keys for Associative Arrays are forced to integer values.  The decimal values are truncated.  Therefore, A=100,4, B=100.5, C=100.4 returns a 3, not a 2 as it should be.  If the significant number of decimal values are known, a multiplier can be added to the formula to force the values to be integers
Choose(N Items((Associative Array(Eval List({:A*10,:B*10,:C*10})) << get keys)
or a restructuring of the code to use Boolean math.
dt << New Column( "SUM2",
	Numeric,
	Continuous,
	Formula( If( :A == :B & :B == :C , 3, :A == :B | :A == :C | :B == :C, 2, 0 )
