dilipkumar
how to store JSL output to a SQL database
Hi ,
i have written some query in JSL and want to save the output  values in SQL data base.
Can anyone help me in doing that.
Regards,
Dilip
Re: how to store JSL output to a SQL database
I am not very experienced in directly interfacing JMP to SQL, however, here is a response from @vince_faller  Writing to an SQL database that writes multiple values.
dbc = Create Database Connection("DRIVER=SQL SERVER;SERVER=fake_database;Database=Test_DB");
sqlreturn = Execute SQL(dbc,
      "INSERT INTO [Test_DB].[dbo].[fake]
VALUES
          ('TestSQLinsert'
          ,1
          ,1
          ,'JMP'
          ,14.14
          ,14.14
          ,1
          ,'JMP'
          ,'JMP'
          ,'JMP'
          ,14
          ,14
close database connection(dbc);
dilipkumar
@txnelson Thanks for Reply.
Actually i have created one table in jmp. I just want to save that table into SQL data base using JSL.
Regards,
DIlip
GM
GM
@dilipkumar Have you reviewed this thread
https://community.jmp.com/t5/Discussions/Save-to-Database-is-too-slow-10k-records-per-minute/m-p/102...
It seems that if you are using JMP13 or later version you may be in luck.
