how to select only those samples that meet two or more criteria
Created:
Sep 22, 2022 11:56 AM
| Last Modified: Jun 9, 2023 8:58 AM(3778 views)
i want to create a new column using Day1_Orig values wherein there are both Day1_Orig and Day1_Repeat values for the same SUBJID. So for instance, lines 113 and 114 have same SUBJID, so the new column would record the value of the Day1_Orig value in line 113 (834), but as there is no corresponding Day1_Repeat value for line 107 (641), this Day1_Orig value would not be included in the new column.
dt = New Table("Untitled 3",
Add Rows(6),
New Column("S", Numeric, "Continuous", Format("Best", 12), Set Values([89, 89, 96, 96, 96, 96])),
New Column("O", Numeric, "Continuous", Format("Best", 12), Set Values([641, ., 834, ., ., .])),
New Column("R", Numeric, "Continuous", Format("Best", 12), Set Values([., ., ., 230, ., .]))
dt << New Column("Test", Numeric, Continuous, Formula(
If(Col Number(:O, :S) != 0 & Col Number(:R, :S), /*check if both :o and :R have value for this :S*/
If(Col Cumulative Sum(!IsMissing(:O), :S) == 1, /* Check if row is first found value for :o for this :S*/
:O
